Moroso oil pickup, possible problem?
and if its an ls1 or aluminum block my book says 106 IN. LB (from 2002 ls1 service manual.) that converts to 8.8 FT. LB.
I have a Moroso pan. (This one: http://www.jegs.com/i/Moroso/710/20140/10002/-1 ) Also, what are people using for dipsticks? Thanks,Alex
I have a 2001 4.8L with a remote oil filter setup (cuz of the pan), and have no pressure issues at all. 45 psi at idle, and had the car to the track, and it was 75 psi at speed. I am using a FRAM Xtra guard 8A filter. I know, Fram sucks, but its what I had access to in short time before hitting the track. I never used a XG filter before, but I was really surprised by the weight of it, and obviously the size of the 8A is allowing extra flow / less restriction and the pressure is higher. Before I put the XG8A on I had a PH43, and it never got close to 75 psi. That XG 8A made quite a difference.
OH, also, the PH43 filter had cheap-o 10W30 going thru it, and the new XG8A has synthetic 5W30 thru it, so thats gotta be making a difference too.
Im using the stick that came with my LH8 kit, whichever that is, probly the Hummer stick. I think if you use a matching tube and stick, the level will be correct.
Last edited by cutlass_455; Sep 28, 2009 at 12:50 PM. Reason: added oil comment. added dipstick info
I used all -10 stuff. So if you add it up, its -10 braided line (~6 ft in total), 2 90* hose ends, 2 straight hose ends, 1 adapter for a pressure point ( http://www.summitracing.com/parts/RU...0/?image=large ), one filter adapter, 2 -10 to 1/2" NPT adapters. Pretty much generic stuff. The adapter accepts PH8A/PH43 filters, so whatever else uses those same threads and gaskets will work. See the pic to see the top end. Down at the pan, its just the 2 90* pointing as straight as possible towards the front of the car.
I too am not a big fan of remote oil filter setups, and Im kicking myself in the *** for not using the Autokraft pan. I even knew about it before, I just got rammy when I got the point of needing a pan and just went and got the Moroso one. I would have had to wait 2 weeks for the Autokraft one. Being in Canada, it takes about 2 weeks to get stuff. Im thinking of upgrading to the Autokraft pan when I put my 6L in next year.
The filter adapter is made of pot metal it seems almost and has lots of casting flash in it, so I did a bit of porting on it to smooth things out a bit. Just be careful not to slip and slice the gasket flange.
The gasket kit I bought (off of ebay) had two o-rings that I believe were for the oil pump pickup (Nothing is labeled in the gasket kit), but neither were as large as the original one, so I'm just reusing it. I read several how-to articles dealing with oil pumps, they all reused the o-ring with no ill effect.
Here you can see my same problem with the pickup tube not square with the oil pump. This is also one of the places where the Moroso tube hits the GM windage tray:
Here is the windage tray after trimming for clearance of the pickup tube brace:
