connector ids
Old Sep 28, 2009 | 08:32 AM
techrunner's Avatar
Default connector ids
i have been digging around in the wiring diagrams without luck, so i'll just ask here. i have an 03 truck harness, and there are two connectors that i can't find in the diagrams down by the starter. one has a two pin connector, one wire black and one green. the other connector is a three pin, a black, a gray, and a red with black stripe. any thoughts? i found a two pin with black and green for the coolant level in the reservoir, but that was up by the MAF. i had two other connectors up there too, which i thought might be for AC, but i couldn't find that stuff in the diagrams.
Old Sep 28, 2009 | 09:31 AM
allpro's Avatar
If the plug is directly above the starter than that is the "crank position sensor", the other one sounds like it goes down to the oil pan on the right hand side lower and is the oil level switch plug. If you post up some pics I may be able to help you better.
Old Sep 28, 2009 | 09:56 AM
the_merv's Avatar
Veteran: Air Force
Post a pic..
Old Sep 28, 2009 | 10:24 AM
techrunner's Avatar
guess i should've specified, i found the crank position and the oil level connectors and got them plugged in, these two are in addition to them. camera is out of town with the wife, or i'd get a pic.
Old Sep 28, 2009 | 11:46 AM
SpecV44's Avatar
those sound like the a/c compressor plugs. they are routed underneath with the starter/crank wires.
Old Sep 28, 2009 | 08:01 PM
allpro's Avatar
Spec I think you are correct. That sounds like the a/c clutch connector and the high pressure switch is a small 3 pin circular connector.
Old Sep 29, 2009 | 11:37 AM
techrunner's Avatar
ok that sounds kinda like them, the one is a circular three pin connector. that means that i now have two up near the right cylinder head that i have to id, cause i was guessing those to be for the ac. think they were both two wire connectors, but i'll have to check to confirm that. any thoughts on those?
Old Sep 29, 2009 | 01:10 PM
allpro's Avatar
Can you give wire colors? They could be for the evaporative solenoid could be one, the other could be for the MAP sensor toward the rear of the truck intakes. The Evap sensor is toward the front of the intakes. Wire colors will help.
Old Sep 30, 2009 | 03:03 PM
MonteHawk's Avatar
Can you give wire colors? Wire colors will help.
"one has a two pin connector, one wire black and one green. the other connector is a three pin, a black, a gray, and a red with black stripe."
uuuuuhhh, ok......
Old Sep 30, 2009 | 06:07 PM
allpro's Avatar
uuuuuhhh, ok......
Monte we already got those for him, he is looking for two more sensors. The ones he was originally looking for were a/c plugs.
Old Oct 1, 2009 | 01:27 PM
MonteHawk's Avatar
My apologies, I am taking my plate of steaming crow and going to go sit in the corner now......
Hope he finds what he needs. People on this site like yourself make it great.
Old Oct 1, 2009 | 02:39 PM
allpro's Avatar
No it's all good man. I am new on here too trying to get it all sorted out! We all need each other to figure out what GM didn't want us to know!!!
Old Oct 16, 2009 | 08:32 AM
techrunner's Avatar
well, sorry it took so ling, but i finally got a look at wore colors last night. there are two connectors, both two wires each. the first is a brown and a black, the second is a blue with a black. both are right up by the passenger side about the middle of the engine on top, and neither is very long. wondering if they are related to egr and evap maybe? any ideas? thanks, nick
