boreing a 5.3
speed pro makes replacement pistons for the 4.8/5.3 that are hung on stock rods and used with stock crank and are around 400$ with rings.
.060 over 5.3 with 4.8 flat tops will make for high compression 5.5 engine.
build with a 22x-230 cam and some 241 or 243 heads and with supporting bolt ons and tune and has the capacity to make 450+bhp engine.
I see you're in Houston. I'm in San Antonio and I am having a hard time finding a 5.3 to start working on. Do you know of anything for sale in Houston? I would be interested in a bare block or even a full engine. I'm just trying to find SOMETHING.
Thanks!
John
3.9 bore with stock crank = 347
3.9 bore with 4.00 stroke =383
so he could be running a 383 or 347 disguised as 4.8/5.3 and taking everybodys $
but then again if its a in correctly setup fox with susp. and has been lightened. it possible hes on stock bottom end with a strong dose.
but if hes yankin em n/a, i would suspect hes not telling the truth about a stock 5.3 bottom end
although if the guy is hustling, it would make sense. but again if the car is leaving too hard n/a, no way its a claimed 5.3 bottom end
