L92 fox mustang build
#42
I got lots of stuff but have not done anything with it.
Headers fit. Alt starter rest of the gaskets. All the hardware.
I hope it is only another week or so on the intake so I can get the block out to the machine shop.
I have all the fittings for the coolant tubes will be an fittings. I also changed the rest of the fittings to black on the fuel system.
Tim
Tim
#44
I put the Comp cams trunion upgrade on the rockers today. Took about 1.5 hours. Used a small Arbor press. What a mess a stock rocker would make if the trunion fails.
Intake looks like the 15th at the best. I can get one today but it is $50 more. Just can't spend that kind of $$
Tim
#46
Well things are comming along.
Got the Hollow stem valves.
Made the jumper harness for the crank/cam sensor to my existing wiring.
I have sold some of my ford stuff so I have the $$ to get the rotating assembly. TSP has a 418 kit with a nice set of wiesco pistons and eagle crank and rods. Going to get that ordered in the next couple days.
Heads are disassembled ready to be shipped to FTI for the works. Cam, springs, retainers keepers, seals, VJ if needed and a mill to clean them up. I don't even what to know what this is going to cost. LOL
Tim
Tim
#48
Major UPS shipment today
Eagle crank and rods
TSP weisco -4cc pistons
TCI flex plate
balancer bolts
oil pressure gauge
I had to return a Hughes flexplate it had a .085" wobble to it. JUNK
The TCI I got today is a very nice part comes with hardware and the crank addapter.
Tim
TCI flex plate
balancer bolts
oil pressure gauge
Tim
#49
Long day at the shop powder coating about everything.
Intake, block, oil pan, valve covers, coil brackets, timing cover, bolts, alt brackets, valley cover
We also did a DSM valve cover, Ford super vic and rails, oil pan timing cover, coated a set of pistons, two diesel truck intake tubes.
Tim
Tim
#60
do you have any pictures of how the steering shaft fit?
I'm using these same headers and am having issues with the shaft.
Right were it comes through the firewall and the stock unit bolts up, that part is pointed right at the header, can't get the lower piece connected, i'll post up some pics.
