L92 fox mustang build
I bought a L92 core with a 6.2 alum block and complete L92 heads.
Planing on doing a 4" stroke 4.080" bore. 11.5 cr
Hyd roller. FTI as always will be doing the cam.
L92 vic jr with a 4 hole TB
I will be using a ford AEM. I have been using the Ls1 coils for a year.
C4 behind it because it has a lifetime warranty.
8" converter that will stall somwhere in the 5800-6000 range. not sure who will build the converter yet Coan or UCC.
Using my custom stainless 1 3/4 headers with new addapter plates from the ford motor.
I still need to get a water pump, alternator, rotating assembly, cam and chain, PR, and rocker trunion upgrade.
This is going to be a cool deal when it is done.
Will put some pics of the car up still has a customer 428" blower motor in the car that I am taking out testing this weekend.
Tim
It's nice to see you here. I want to see this set up materialize and see it running strong at the track because there's no doubt in my mind it will.
As for the converter, I talked to Lenny to modify my current converter made by him and he told me that he don't know what's required to make it work with the C4. The folks from J.W know what needs to be done and they quote me $300-350 to do it. Maybe Coan can build you one outright that doesn't have to start as a C4 converter and then modify it.
Keep this thread updated as you go since I'll be looking forward for my build early next year.
Good luck!
The car has been 10.115 with a pump gas na 408 ford motor drove on drag week.
Tim
Tim
Did we meet on drag week this year?
this is a blower motor 9.8-1 with blower cam.
I only expected 10.50's
This ls1 needs to run at least that good
Tim
Should be a nice build and def. a quick ride for sure, keep us posted man!
Tim
Valve covers, alt bracket and hardware, AJE mounts, Exh rockers and bolts for all of them, some gaskets.
Going to order a bellhousing for the c4 soon.
then I can get it in the car and see if the headers will work.
Tim
