LS6 Porsche 964 build
re: 911 radiator
>Do you have any shots of the radiator setup? I was
>actually thinking of this exact swap earlier today and was
>wondering if there was a good way to mount the radiator
>in the front instead of horizontal in the tail.
Mine is a 85 Carrera, but the radiator setup is very similar.
Pics at http://hatfield.homelinux.com/porsche_v8.html
Regards,
Ken
Regards,
Ken
Regards,
Ken
Regards,
Ken
This is the plan for 2010-2011 winter
Beautiful car Ken. What do you have done to your motor? Are you running the 915 trans? Where did you run your water lines to the front?
BTW, I would never mount the rad in the rear. Looks bad (fans are visible from the outside of the car and the wing is not a factory design). Adds weight in the absolutely worst place to add weight.
Cheers, Russ
Russ,
Thank you.
More details in this thread:
https://ls1tech.com/forums/conversio...che-911-a.html
Regards,
Ken
Thank you.
Regards,
Ken
