Wiring Harness Merging Company
I have a 95 Impala SS, I am currently putting an LQ4 with L92 heads and a L76 intake in this vehicle. I currently have a SPEARTECH Harness for this vehicle but I am looking for a company that will merge my factory harness with the SPEARTECH Harness. The Speartech harness is labeled. I am looking for a custom plug and play harness that looks stock. Thank you in advance.
My harness is similar, I had jared at curent performance make it, and John at Speartech fix it, but either way with either of these folks, you tell them what car you are putting the lsx into and they build the harness to your specs for a plug and play. That is how mine worked once it was fixed. You feed to ignition, gauges, and cruise and you are done. In your case you probably do not need to feed to guages as the one wire cold do all of that.
Well I attempted the same thing you're doing now and unfortunately no one on this "spectacular" forum quite understood what I was willing to pay for or.... So I found a guy somewhere else who reworks harnesses and I offered to buy him the factory shop manuals for the Imp-SS and pay him if he was willing to take on the job. He has both harnesses and I'm waiting for him to complete them. If all goes well, I'll give you his info so that you can get exactly what it is you're wanting.
Speedscenewiring.com has finally answered the call by us B-body members wanting to have a plug and play wiring harness for the 94-96 ImpalaSS LS series engine swap. But it does cost for the ease of convenience.
All anyone needs, are the GM Service Manuels for the particular model & year vehicle. The wiring diagrams are in them. Contrary to common beliefs, they are very easy to read & understand. This job of marrying the six or so wires from the the main drivers side firewall plug, to the LS engine harness, is extremely simply. Anyone can do it with the Service Manuels. I enjoy understanding & learning the wiring codes, so I know what to do if, say a guage doesn't work perfectly, I don't have to de-rig everything again, and ship it off for a fix. The Manuels come in handy for everything else on the vehicle as well. Good luck with your Impala SS. I had a black '95 as well. Great cars.
**** if you know someone at GM have them print off All Data diagrams..they are perfect for swaps.
And yes..it is really simple..ground the grounds..power the Pinks(Ignition) and Oranges(Constant), and put the Signal wires to the right places.
That's the secret fellas..it's out now..
