Plug for oil level sensor bung.
'67ls1camaroProject, The sensor is about 4 inches long and is in the way of the oil pickup inside the pan. The pan and pickup were modified by S&P.
it's not that big of a deal to pull the pan though if the engine is not installed yet. Sounds like you have to figure out why the pickup is out of place. With the modified pick up tube does it still bolt to the windage tray? If nothing else after you figure out that the pick up tube will work. Maybe you can epoxy any hole after the stem is cut off the sensor.
