63 nova
Old Nov 16, 2009 | 08:25 PM
danbap's Avatar
Default 63 nova
has anyone put a 5.3 or other ls based engine in one? my dad is thinking about swapping out his straight 6 for a v8 I'm trying to talk him in to a 5.3l but the problem comes up for headers and oil pan. any one have any suggestion on either one? thanks. will an oil pan from a older 350 fit a 5.3l?
Old Nov 16, 2009 | 08:29 PM
psiconversion's Avatar
LS1Tech Sponsor
Good question. My brother has a 67 that we have a 327 in. That old oil pan will definitely not work. You may have to go with an aftermarket subframe like Chris Alstons, etc.
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Nov 22, 2009 | 02:48 PM
mglover9558's Avatar
I'm in the process of putting a 5.3 in my 63 wagon. You can use a gto oil pan with the front sump. I haven't found any headers that work with the stock front clip. Everyone that I've seen had custom built headers.
Old Nov 22, 2009 | 05:25 PM
gnnova's Avatar
Go to http://www.stevesnovasite.com/forums...t=58071&page=8 They have a thread for LsX swaps into novas.
Old Nov 22, 2009 | 05:26 PM
danbap's Avatar
ok thank you both for the help. if custom headers are in order i dont think the swap will happen.
Old Nov 23, 2009 | 08:03 AM
TomM's Avatar
Two companies are working on headers for a stock clip... BRP and Church Boy's Racing, they should be out hopefully by the end of this year....don't give up on the swap, it will be the best thing you have done for the car, driveability is off the chart....
T,
Old Nov 23, 2009 | 11:05 AM
LS1Tech Sponsor
I agree with TomM. If worse comes to worse put manifolds on it until you can get the headers done.
__________________
Ebay Store
Old Nov 23, 2009 | 11:48 AM
NemeSS's Avatar
headers and acc. shouldnt top u from going thru with swap, a solution is well worth it
Old Nov 23, 2009 | 04:14 PM
danbap's Avatar
lets hope they come out with them at a decent price. thats true just to run the manifolds my dads not looking for power just a nice driver. how hard is it to keep the fuel injection? i have to talk to him more about it to see if he wants the fuel injection im not thinking so because he is an old school kind of guy with a carb.
Old Nov 23, 2009 | 06:16 PM
TomM's Avatar
They will probably be in the 5-700 dollar range, but that's just a guess. Your choices are limited on a stock clip with manifolds, many have tried, and no one has found a manifold to work yet, unless they flip them to run a turbo, there is just no room......the 06-09 vette manifolds look promising, but haven't heard of anyone trying them, and I'm sure they would cost as much as headers anyway...
I would have stuck to the stock clip if I could have worked it out, but just didn't feel like building a set of headers.....
I'm not even going to open up the carb/FI debate.......personally, the reason I did the swap was for the FI, driveability, mileage, and the inate ability to add some serious horsepower with just a cam swap, and not have to rejet a carb and set timing etc......
If he's old school, just say "look dad what neat injectors Hilborn came out with".....................and then run....
T,
Old Nov 23, 2009 | 06:28 PM
danbap's Avatar
i guess his project will be on a pretty good hold untill headers come out, he dosn't want to chop up the firewall since he just restored the whole car last winter, haha to the hilborn injectors.
Old Nov 23, 2009 | 07:09 PM
eviltwin_1987's Avatar
there are no manifolds that will fit with a stick front end. upside down or not
Old Nov 24, 2009 | 03:47 PM
danbap's Avatar
good to know thanks.
Old Nov 25, 2009 | 02:14 PM
Joe Nova's Avatar
Default my two cents worth
If you go the route of a TCI (Total Cost Involved) or Heidts front end you can use the TCI headers and they fit both brands of front ends. I have a Height front subframe and the TCI headers fit like a glove. They come ceramic coated and run approx 670.00 . I bought mine through Tim's Hotrod on E-bay. For an oil pan use one from an f-body
Old Nov 25, 2009 | 04:25 PM
danbap's Avatar
could i just use a set of v8 swap headers and cut the flanges of and weld on a set of ls flanges?
