does anyone know mpg for a carb 6.0
Old 11-22-2009 | 10:11 PM
Rundeep66's Avatar
Default does anyone know mpg for a carb 6.0
I just got my stock bottom 6.0 running. Just wondering what to expect for mpg. Its a Carb 6.0 here is what I got
750 double Pumper, 620 cam, 240 duration 108 c/l, fully ported 317 not milled, gm single plane intake, 350 trans 4000 convertor, 410 gears with a 12 bolt, my truck should be around 3300 lbs. I got headers, flowmaster mufflers.
I was hoping for 14 to16 mpg
Old 11-22-2009 | 11:42 PM
Paul57's Avatar
I am not an MPG expert but I don't think you will get that (14-16) with 4.10s and that cam...not at 60+ mph, anyway. If you had an overdrive tranny such as the 200-4R that would help. I know of a builder that has them rated up to 1000hp if you're worried about strength.
Old 11-23-2009 | 12:26 AM
kdavis's Avatar
a 2wd 2500hd only gets like 16 highway and they have 4.11 gears
Old 11-23-2009 | 01:06 AM
dimetweaker's Avatar
and they have an automatic overdrive transmission to aid that as well... not looking good!
Old 11-23-2009 | 01:46 PM
Rundeep66's Avatar
Well I'll be finding out in a week or so. The 2500 hd has a lot of rotating mass it has to move. 50 lbs a wheel, a few extra pounds like maybe a thousand or more.
Old 11-23-2009 | 02:24 PM
spacemanspif's Avatar
Don't forget that driving style is a HUGE factor in the gas mileage game.
Old 11-24-2009 | 01:02 PM
LS1GMCTruck's Avatar
And they have the much better gas mileage, computer controlled fuel injection...also not looking good.
Old 11-24-2009 | 03:40 PM
NemeSS's Avatar
its subjective,
too many ppl assume carb= bad mpg
but really its how well the carb is tuned for the motor its on top of and if the cfm rating, jetting, etc. is correct.
Old 11-24-2009 | 09:38 PM
Paul57's Avatar
I agree.
A carb should get the same fuel economy as fuel injection if the air/fuel ratio's are the same.
Old 11-24-2009 | 10:06 PM
mred's Avatar
10-12mpg w/4.10s
4.10 eeek might kick yo ***.
might want to run some 3.42s or 3.55s 14-16 and drive it right.
i had close to the same set up and even ran a 28" tall tire all the time
650dp holley
but keep us posted.....
Old 11-26-2009 | 04:07 PM
Default 1996 GMC Truck
28" tires, 3.42 Eaton Posi 10 bolt, LS1 4L60E, 27 mpg hwy.
Old 11-26-2009 | 11:11 PM
mred's Avatar
Old 11-27-2009 | 05:28 PM
Isolde's Avatar
That works out to 1800 rpm at 65 mph. I had a '78 Camaro, carb'd 350 with 700R-4, 3.08:1 and 26" tires, it did 26 mpg at 65 mph, which also was 1800 rpm. I strongly suggest 1800 at 65 if you care about mileage.
Old 11-27-2009 | 05:39 PM
deelong4002's Avatar
I would think it's possible to get 14 to 16 easily if you have it tuned spot on. If not, who knows then.
Old 11-27-2009 | 06:19 PM
726.0chevelle's Avatar
13 Second Truck Club
i think barely touching double digits if it ever sees them
Old 11-27-2009 | 10:40 PM
52 Rat's Avatar
My '05 HD 2500 has the 410's with the LQ4. 13-14 mpg is it for me. Good luck.
Old 11-28-2009 | 12:43 AM
Paul57's Avatar
I believe that has a 31" tire also, correct???
Old 12-12-2009 | 07:39 PM
Rundeep66's Avatar
Well my truck is not doing the best for mpg. I just can't keep it under 3500. It's a blast to drive. I think I need a new Carb I'm getting a backfire and the truck will cutoff. But it will start right up besides that it's super fun. The weather in Chicago sucks
Old 12-13-2009 | 11:42 AM
63chevyll's Avatar
When I had my stock carbed 6.0 w/small cam (206 210 duration) in my 63 chevyll w/4.30, th350, and 28" tires. I got 11 mpg without carb tuning.
I think 12-14 can be done with a carb.
derrick
Old 12-17-2009 | 12:44 PM
Rundeep66's Avatar
I'm looking to buy another Carb. I'm going to start back driving it after the first
Quick Reply: does anyone know mpg for a carb 6.0
