PCM mounting options
Old Feb 2, 2011 | 02:12 PM
gofastwclass's Avatar
Originally Posted by RKBJR
Will the PCM from an '02 5.3 fit in the S10 bracket?
Yes it does, that's what I'm using. I found one in the 'yard for cheap, built a bracket for it and welded my bracket to the car so I could bolt down the PCM bracket. The only deal is you need a newer S-10 with the bracket that looks like the one 1976Camaroguy and I posted back in '09.
Old Feb 2, 2011 | 02:27 PM
1976CamaroGuy's Avatar
I think the PCM's are physically the same on the outside.
Old Feb 2, 2011 | 02:40 PM
Steve68's Avatar
from Ironworks, inside or outside,
Old Feb 2, 2011 | 04:21 PM
crosstraining's Avatar
Originally Posted by FastKat
BTW, I wound up using the C5 Corvette PCM mounting brackets. It is a compact 2-piece setup that sandwiches the plug-side of the PCM. It is very versatile. You can see some pictures at my website:
http://www.buyrcars.com/jag.htm
FastKat, that is an awesome website and write up!!
Old Feb 2, 2011 | 04:25 PM
Originally Posted by garys 68
Thanks for the S10 part number, ordering one today.
Where did you order it from?
Sorry, I see you got it at Ironworks
Old Feb 2, 2011 | 06:32 PM
2165 Turbo Rail's Avatar
i used 98 - 02 Camaro mount and just cut off the portion that would normaly bolt to the inner fender then screwed it under the dash and slid the computer in
I forgot to get pics
Old Feb 2, 2011 | 06:34 PM
Earl Filter's Avatar
Yes, and I thank him for the tutorial...uhh, I mean write up!
Old May 19, 2011 | 01:25 PM
john.starkweather's Avatar
I ordered the s10 mount and relized I had a different PCM. I have The 1997-98 Vette computer #16238212. What mount from GM will work for this?
Old May 22, 2011 | 03:19 PM
LS88FoxBody's Avatar
Got a link to their website?
http://www.pro-touring.com/showthrea...Home-builder.&
Old Jun 16, 2011 | 11:42 PM
I went to GM to order the mount for my PCM and they said the part number was discontinued and there is nothing that supersedes it. I ended up making a mount out of a strip of aluminum.
Old Jun 17, 2011 | 04:58 AM
2xLS3's Avatar
If you want a mount for the 97 / 98 style PCM look in the classifieds and find somebody looking for the 99 and newer mount, because they upgraded their PCM, and buy their old mount
Old Feb 28, 2015 | 03:13 PM
  #32
Bdiddy's Avatar
I scored my 411 pcm with the mount for 20 bucks from a local self service yard. It was in a 01 express van under the master cylinder on the inner fender. One of the mounting tabs stick off the bottom at a weird angle for the curved fender mounting surface. I will have to cut it off for a flat firewall mount, but it will work for my slim budget.
Old Jun 8, 2016 | 03:42 PM
  #33
Grewe02's Avatar
Bumping this for any more replies.
I have the 97 - 98 PCM as pictured here, anyone know of an off the shelf solution? Otherwise this doesn't look too difficult.
Old Jul 7, 2016 | 11:41 AM
  #34
chuckd71's Avatar
I got one of the 15995679 for $14 from this guy, was the cheapest I've seen them. http://www.ebay.com/itm/GM-OEM-Ignit...kAAOSwwo1XdueZ
Old Jul 7, 2016 | 12:37 PM
  #35
sddel40's Avatar
I used Velcro to mount my 411 under the pass seat on my 56 Chevy have 2 411 and can switch in 5 minutes the computer does not have to be grounded
