PCM mounting options
Old Nov 27, 2009 | 04:51 PM
FastKat's Avatar
Default PCM mounting options
What mounts are you guys using to mount your late LS1 PCMs in your engine bay? I understand that the S-10 mount is popular, but that it only works on 1998-02 PCMs.
Has anyone tried the later 2-piece C5 Corvette mounts?
Thanks -Dave
Old Nov 27, 2009 | 08:26 PM
jonathan_ed3's Avatar
What is the S10 mount? I was just going to shove mine under the dash...
Old Nov 28, 2009 | 03:46 PM
FastKat's Avatar
I'm not entirely sure... I found a few threads where people talk about them being a good PCM mount for 1998-02 LS1 PCMs, but all of the pictures they posted are gone.
I was hoping to get some guys to post up what OEM mounts they're using so we can see dome of the different ways to mount the PCMs.
Old Nov 28, 2009 | 04:55 PM
Pocket's Avatar
Im using one off an 01 van. Its the whole battery tray assembly with the big bracket cut off so I can bolt it anywhere
Old Nov 29, 2009 | 07:44 AM
FastKat's Avatar
I've seen the van mount - I think the plastic sleeve has tracks on the back of it... did you slide those tracks into something or did you just mount the plastic sleeve that holds the PCM?
Old Nov 29, 2009 | 08:32 AM
726.0chevelle's Avatar
13 Second Truck Club
im using the bracket off an 03 van one end slides in and the other side has a clamp that goes across works nice and is not much bigger than the pcm
Old Nov 29, 2009 | 04:43 PM
FastKat's Avatar
Here are some drawings (from GM Parts Direct) of the '03 van PCM mount and the '04 Corvette PCM mount, which seems to be two pieces.
I'm tempted to by both and see which ones work best.
Any other pictures/input?
Attached Thumbnails PCM mounting options-2003-express-van-pcm-mounts.gif   PCM mounting options-2004-corvette-pcm-bracket.gif
Old Nov 29, 2009 | 09:32 PM
poconojoe's Avatar
Those are to mount 2 totally differant PCMs or somebody needs to learn how to draw, since I did look it up and both those aplications should have the same case. By the way the S10 mount should fit all the PCM's that take the 2 80 pin connectors.
Old Dec 17, 2009 | 08:41 AM
1976CamaroGuy's Avatar
Anyone have the part numbers or a link to the S10 mount? I need to order some stuff from GM parts direct and want to include this mount.
Old Dec 17, 2009 | 10:50 AM
TomM's Avatar
98 mount is different than 99 and up for F-body, I had to buy both to figure that out......
I made some "L" brackets for mine and screwed the to the sides of the mount and then mounted it under the dash.....
T,
Old Dec 17, 2009 | 11:57 AM
bczee's Avatar
I used a s-10 mount, cut the bottom mounting tabs off. then bolted it to a peice of strap metal that was then mounted to my trans tunnel.. I just used the PCM mounting part of the mount.
I would say just use any mount that the PCM will accept and secure it, then just mod it...as the mount is only designed to work for the the car/truck it was designed for and is not going to be a perfect bolt on in the 1st place.
Old Dec 30, 2009 | 12:11 PM
Here's a picture of the 1998 – 2004 S10 mount part# 15995679
I got mine off eBay used from a seller s10partswarehouse
Hope this helps, it looks like it can be modified for a variety of applications
Front:
Back:
Old Dec 30, 2009 | 03:51 PM
gofastwclass's Avatar
That looks better than what I'm using. GM Parts Direct has them for $12 but they wanted $15 to ship it - AND it's a special order part so no returns if it doesn't work! I may go to my local GMPP dealer where they match GMPP's prices and know me a little too well to see what they say.
What year PCM are you using and does it fit ok? I found some people using it and they had pics but I don't have any idea what PCM or car it is for. Mine is a 2000 truck and my PCM looks very similar to the pics I found below. I assume this is for a Grand Prix since the site is called club GP...
Old Dec 30, 2009 | 03:58 PM
I haven't checked the fit but my 2004 silverado Truck PCM looks real similar to the PCM that's on my 2000 S10. I should have my silverado PCM back in a few days from the programmer.
Old Dec 30, 2009 | 04:06 PM
Spike-Z's Avatar
I need a bracket too. 02 "411" PCM here, will it fit in the S10 bracket?
Old Dec 30, 2009 | 04:17 PM
Not sure but I did some searches on eBay for S10 and Silverado PCM and both came up with the same "411" PCM number.
I'm pretty sure it's the same PCM physically.
Old Dec 30, 2009 | 05:06 PM
BBPanel's Avatar
Veteran: Marine Corps
My 411 PCM fit the S10 bracket - in fact it fits so well I don't know why the hinged wire piece is even necessary. One of the plastic edges is angled and you may have to grind it down for it to lay flat - not a big deal. -Bob
Old Feb 2, 2011 | 11:23 AM
RKBJR's Avatar
Will the PCM from an '02 5.3 fit in the S10 bracket?
Old Feb 2, 2011 | 01:10 PM
FastKat's Avatar
BTW, I wound up using the C5 Corvette PCM mounting brackets. It is a compact 2-piece setup that sandwiches the plug-side of the PCM. It is very versatile. You can see some pictures at my website:
http://www.buyrcars.com/jag.htm
Old Feb 2, 2011 | 01:50 PM
garys 68's Avatar
Thanks for the S10 part number, ordering one today.
