99 ls1 power steering hook up to 69 camaro
THE WAY I DID IT WAS TO GET THE ADAPTOR FITTINGS TO AN6 FOR BOTH SIDES AND THEN RAN A BRAIDED HOSE THE PRESURE SIDE I USED TEFLON HOSE FOR THE RETURN SIDE IT WAS JUST STAINLESS STEEL BRAIDED HOSE
Originally Posted by 68LSS1
S&P sells metric to flare adapters.
They will probably require your first born!!
I just used Russell stuff from Jegs or Summit. Bought the braided PS hose and the proper fittings to convert the 11/16 to metric. My steering box was from an 88 Monte SS. Cost me around $65 to make it myself.
![Wink](https://ls1tech.com/forums/images/icons/icon12.gif)
Originally Posted by datsbad
i was wondering how everyone was hooking up the factory power steering on the ls1 to a 69 that has power steering .
Hopes this helps, Rodney
Im running the fbody PS in my 69.. no problems.. had a custom line made from the pump to the box using the fbody end (from the high pressure out side of pump) combined with the right stuff for the gearbox ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Then again my gearbox is the new Saginaw 600 unit (with pinion valve) and its metric.. but the principal is the same
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
