Need PNP (park neutral switch) wiring diagram or pin outs
#41
I don't know exactly what it changes, but I do know that it's needed if you ever need to do a crank relearn, so the PCM is using it for something. Similar to the wire in an F body that needs to be grounded in park and neutral. I'm sure someone smarter than me would know more about it.
#42
Andrew
#44
As of now, I am going to wire the inputs to my Dominator ECU. At the very least, I will be able to display PRND on my digital dash, and maybe use them for some tuning.
Andrew
#46
I wired this up recently on my 2000 5.3 swap. I had to add the extra wires to the harness. I didn't notice any difference at all in how the engine behaved, but I could see the selected gear in HP Tuners, so I know it was working correctly.
#47
I have a 2003 Tahoe LT with 5.3 and 4l60e, previous owner messed up neutral safety switch and the 6 wire pigtail. I replaced both but the wires on the newish pigtail doesn't match the wires coming from the trucks harness. My truck doesn't have a purple wire but does have a grey one among other different colors. Where can I find the correct color scheme for a '03 Tahoe? Thanks for any help.
