re-working wire harness
Old Dec 28, 2009 | 07:27 PM
crosstraining's Avatar
Default re-working wire harness
I am considering re-working my wiring harness myself. I have the schematics. Is there some FAQ or thread or place that has the typical things/wires removed from the harness?
Thanks
Old Dec 29, 2009 | 06:25 PM
vandejr's Avatar
www.lt1swap.com has a tone of info. i made my own and saved between 400-750 bucks.
Old Jan 3, 2010 | 08:43 PM
VANDEJR, Thanks. Tons of good info there.
What year/vehicle of harness did you do? I have pulled out all of the (yellow highlighted) pins that are not needed. I have not taken them out of the harness yet. Nervous I guess. I leave the green highlighted one in right?
Anyone can chime in with input.
Thanks
This is the page where I got the info:
http://www.lt1swap.com/2004vortec_pcm.htm[/EMAIL]
Old Jan 3, 2010 | 11:20 PM
Rubidon's Avatar
The green highlighted ones will come from C2 - Underhood Fuse Block connector,you can use the underhood fuse block or make your own the same web site shows you how. I just did the same thing this weekend and I don't have the block so I will be making my own, all the pink wires need keyed voltage and the 2 orange ones need power from the battery. The other wires that are strays from the pcm are for other stuff like the tach and a few others.
Old Jan 4, 2010 | 08:29 PM
Do you have a build thread or any pics of your wiring?
Do I really need the knock sensor wires? i don't plan on putting the knock senosrs back in.
Old Jan 4, 2010 | 08:46 PM
Is there really no where else to find wire harness info? Do most people send them off for someone else to re-work? Lt1swap has some good info, but I need a little more detail since I'm a newbie.
Edit: I did find some more info in faq, but I can always use more if anyone has other info.
Old Jan 4, 2010 | 09:11 PM
Pocket's Avatar
http://www.thirdgen.org/techboard/lt...ml#post4305264
Old Jan 4, 2010 | 09:13 PM
ls1nova71's Avatar
Any reason you're not putting them back in?
Old Jan 4, 2010 | 09:35 PM
The guy helping me said I wouldn't need them. Is that not the case??
I know just enough to get myself in trouble
Old Jan 4, 2010 | 10:00 PM
Sweet, thanks!
Old Jan 4, 2010 | 11:36 PM
G-Body's Avatar
sawzall wielding director
If you are keeping the EFI I would keep the knock sensors. Theres really no benefit to eliminating them.....I would rather have them there and know that if the engine starts to knock the PCM will figure it out and retard the timing. If you don`t run them the PCM will not do anything and the engine will continue detonating till you figure out whats going on and fix it, or the engine hurts itself
Old Jan 5, 2010 | 05:40 AM
1976CamaroGuy's Avatar
Are the connector(s) for the MLPS switch for the tranny built into these harnesses or are they stand-alone?
I have a 2004 harness and can't seem to find the connectors
Old Jan 5, 2010 | 08:37 AM
gofastwclass's Avatar
My 2000 truck harness had them. The connectors are hard to get out without persuasion because of some goop that gets put on them at the factory. They may have been cut.
Old Jan 5, 2010 | 07:31 PM
Thanks for the info. I guess I'll keep them. I don't know why he said to take them out. I have not had a chance to talk to him.
Thanks
