"Bad" ebay deal...
List of needed parts:
1. PS Pump Pulley. GM#=12559885 Correct??
2. PS Pump Reservoir. GM#=???????
3. Clutch MasterCylinder, Reservoir and Hose. I already managed to get those from ebay 2 days ago. Do you think I can reuse the hose or should I buy new one. How does it connect to the SlaveCylinder?? Orginal one was cut right outside the transmission case.
4. O2 Sensors. I just managed to get 3 used ones from ebay. They are from 2000 model. Hope they are not broken.
5. IAT Sensor. GM#=????? Does LT1 engine use same kind of sensor?? I was checking out Jegs catalog and they have "IAT relocator kit 561-61630" for LT1 engine. That would be perfect for me.
6. Spark Plug Wires. Few were missing. I was thinking to buy MSD Wires from Jegs.
7. Serpentine Belt. GM#=???
8. And the engine didnīt have cats on it so I have to make own exhaust pipe plates.
Well, maybe that will get me somewhere. Iīm sure I will have tons of guestions later on when I get my swap started. Okey, I have already found the answer for most of them from the board, so thanks to everybody who is sharing their knowledge.
Mika
Also, he has GREAT prices on this stuff.. and his service is top notch..
I bought a similar engine for my RS...and it turned out the leak down was bad..42 in one cylinder and 35 in adjacent one. In other words, my motor will have to be re-ringed before it can be used.
The engine was bought from The Parts Exchange.com. They have very good ratings. The ebay deal and shipping to Finland was handeled by one Finnish agent in Florida. I took almost 1 month till he recived the engine. He informed the seller about missing and broken parts and they promised taken care everything like next day. Well, after two months waiting nothing. No reply for emails or phone calls. Until now!? Now someone called from there and said that they will look into it. So, maybe there is light end of the tunnel, heh. Anyway, I allready spend 140 bucks for the parts what they should send to me.
We did contact the ebay and they said: "In reviewing item xxxxxxx, I found that this listing ended over 60
days ago. A Fraud Alert can only be filed online with eBay between 30
and 60 days from the end of the listing. Although you will be unable to
file a Fraud Alert in this situation, if your other attempts to resolve
the matter do not work out, you can file a Protection Claim within 90
days of the listing close. Under the eBay Buyer Protection Program, most
items on eBay are covered for up to $200 (minus $25 to cover processing
costs)."
Otherwise the engine and tranny looked nice. It sits in my friendīs garage and we took apart every accessories and tranny from the engine last weekend. Everything looks good. But like Black Bird suggesed I will do the leak down test before final instalment.
About the parts. Any help for there?? Has anyone used this kind of IAT Kit? http://cgi.ebay.com/ebaymotors/ws/eB...ory=33557&rd=1
Oh, and about the LS1 clutch Master I should be fine with it. Or what you think? I have seen tons of pictures how people have use it on 1st and 2nd Gens. Just little fabricating...
thanks,
Rick
ps. I have MANY good seller refferences of fof this forum and many others...
The air temp sensor can be bypassed with a resistor and the hose to the clutch throw out bearing just pops in and out. Use a pair of needle nose pliers to push the white retainer in and at the same time pull the hose out. The new one just pushes in.
FYI-I guesstomate that 25% of all my ebay purchases go bad or I do not get what I bid on.
What kind of resistor should I use if I bypass the IAT sensor? Is there any drawbacks if I do that? I donīt mind to buy relocation kit if it is better option.
I think, on many ebay deals you donīt get exactly what you should, is bacause different people make bussines in office behind the computer and phone. And then there are different guys who actually pull down the parts what you have bought. The guy who is selling the engine or part for you probably havenīt even seen the stuff what he is selling. You know what I mean.
I always call my local Chevy dealer and get his price and part number, then I just order it online from gmpartsdirect.com. They can't order it unless you come down and pay for it with a credit card. So, I just ask for the part number so that he doesn't have to look it up again when I come in. I just never come in.
Reservoir part # 26068934
These part numbers are for an F-body LS1
I just bought both of these items from the dealership and these are the part numbers that are on the boxes.
Any help with that IAT sensor. Should I use one and relocate it or should I use resistor? And what kind of resistor will work? Any opinions?
Happy Holydays to everybody
