1994 camaro 5.3LSX/TH350 swap 56k is dead
well over the past couple months i prepped/sanded/painted the car and now its time for the motor swap so i figured i'd post some pictures of everything so far
build list
94 v6 camaro
5.3L LSX 90k
LS1 intake (need to change to LS6 or vic jr. with an elbow)
28.8# injectors
218/224 .550/.550 114lsa
TSP pushrods
LS6 springs
ARP rod bolts
1 3/4" Stainless LT's (gonna go Catted H and Magnaflow bullets dumped at the axle)
TH350
B&M shift kit
hughes adapter
3500 stall
as far as suspension goes all i have so far is Double Adjustable LCA's but i will be getting a tunnel mounted torque arm ( or Track pack) and ill be building a set of subframe connectors
for the rear end i have 4.10's and posi
build list
94 v6 camaro
5.3L LSX 90k
28.8# injectors
TSP pushrods
LS6 springs
ARP rod bolts
TH350
B&M shift kit
hughes adapter
3500 stall
so far what i need for the car is
ls1 k member
solid motor mounts
steering rack
tunnel mounted tq arm
tranny cooler
exhaust
tune
then i have some little interior parts that were broke when i got the car that need replaced along with the headlights and tail lights
ls1 k member
solid motor mounts
steering rack
tranny cooler
exhaust
tune
well one day my brother talked me into starting sanding it so once i started i couldnt stop or it would go to waste...
but yah i wish i would of done it the other way... the engine bay will be getting painted the same Hugger Orange here soon while the motors out.
