ok, im about to push this thing into a wall
Now: I kept on thinking it was my harness so we got a new professional built stand alone harness. Put it in and it started right up. Started multiple times throughout the afternoon. Last time we started it, it just stopped running. Now no spark, no injector pulse, and I cant connect to the ecm. i tried two other ecms and still nothing.
So WTF is wrong with this thing?
all connections..ground and positive,,but you probly already did that,,right..
i think your def not getting any power/ground to ecm, check from there
electrical is pain,,
but i will be added ground and ground from the battery directly to the block. I truely hate this car
I drove for months after a conversion, then blew a fuse that shut me down. Traced it to my fuel pump relay, replaced the fuse drove another 2 days, popped it again. Cleaned grounds, replaced the relay and haven't had a problem since. Bad grounds can cause weird problems.
I learned in the car audio world that self tapping screws are NOT good grounds.
Take a multimeter and measure the loss of voltage on both the plus and minus side of the ecm and make your way through the wiring, fuses and relays. "simple as that"
