Intake swap
Old Jan 26, 2010 | 11:03 AM
stewdy1's Avatar
Default Intake swap
I have a lq4 goin In a coupe I have a ls1 intake off a 97 vette
will truck injectors work or do I need to get ls1 injectors and same question for
fuel rail? I'm using an aero a1000 pump and reg so the reg will be my return.
Old Jan 26, 2010 | 11:43 AM
gofastwclass's Avatar
You will need car intake, rails and injectors. If you have a regulator buy rails with only one port.
Old Jan 26, 2010 | 11:55 AM
stewdy1's Avatar
Thanks Alot keep hearing that they will work then hear they won't work appreciate it
Old Jan 26, 2010 | 11:58 AM
garys 68's Avatar
If you go to the truck forum, you can find that others have used the truck injector/rail in a LS1/6 intake. But if there's a height clearance issue, the fuel rail sticks up a long ways. I got an LS1 intake, injectors, and rail for under $100, swapped the LS injector plugs, and had the computer reprogrammed for the injectors when the VATS, O2 sensor, etc changed.
Old Jan 26, 2010 | 12:06 PM
battsup's Avatar
This is a pretty comprehensive thread.
http://www.ls1truck.com/forums/front...take-swap.html
Read it a few times, there's a lot of info there, helped me a lot.
Basically you don't need a custom idler pulley bracket, you can use a longer bolt and some washers. You also don't need to switch you waterpump because you can heat up and twist the inlet/outlet so its no longer in the way. The lS1 style plugs are part# msd-2400. I haven't found any other ones, if anyone has a cheaper source please post up.
Old Jan 26, 2010 | 12:19 PM
stewdy1's Avatar
Alright thanks for info guys now what's the diff between truck coils and ls1 coils guy wants to trade me my truck coils for his car coils
Old Jan 26, 2010 | 12:26 PM
garys 68's Avatar
I've heard a variety of things about coils, just keep the coils that go with the computer and harness, no worries.
Source for LS1 injector pitails.
https://ls1tech.com/forums/conversio...-adapters.html
Old Jan 26, 2010 | 02:25 PM
stewdy1's Avatar
Ok I found a set of 99 vette injecters and prob just do aftermarket rails
Old Jan 27, 2010 | 08:58 PM
stewdy1's Avatar
Ok I got rails and injectors on now where does the plug that is on thE
very top of the truck intake it's the one that seals up a hole bout 1/4 big
Old Jan 27, 2010 | 11:09 PM
garys 68's Avatar
a pic would help
Old Jan 28, 2010 | 05:41 AM
stewdy1's Avatar
Can't get a pic till tonight it's a three wire plug that is on very top and towards the
back of truck intake. It's held in the intake with clips looks like some type of gromment or
somehing. I think the same provision for this plug is on very back of ls1 intake by the vacuum ports
Old Jan 28, 2010 | 08:16 AM
garys 68's Avatar
MAP sensor?
There's also a purge solenoid, near the front. Cant remember the wire count.
Do you have a wiring diagram for your motor? That and the wire colors should confirm.
Old Jan 28, 2010 | 09:22 AM
stewdy1's Avatar
Might be map sensor the sensor on top near front also takes a quick connect line which I believe run down with fuel lines. The plug I'm talkin bout only takes electric plugs but has rubber grommet that fits in top of intAke
