..... Buy 6.0L or LS1 engine for Blazer K5???..................
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
I am going to do swap for my blazer but, I am confusing which engine to choose?
The car will be daily driver, sand, mud, some street race for fun.
Which engine should I take?
5K will get you a decent ls1 setup maybe around 450ish hp with a stock bottom end and full bolt-ons. i want to do a 6.0 set up in my camaro but need arond 10k for a decent set up so if that help any. i just did a heads cam top end kit with full bolt ons and i have 150 shot of juice. havent sprayed yet and it needs to be tuned but im hoping for 500+ with the juice. HOPEFULLY
i think it should hadel it just fine but bigger cubes is more power. i just threw together a 383 stroker thats about the same HP as my ls1 for my 77 chevy truck & thats about the same weight as ur app. i would of put a ls1 in but its to much work & i have 2much in to it. $18k in toa $4k truck. money is going to be ur biggest thing u can buy a used ls1 for $1300 a put full boltons & a tune & ur going 2burn most of that $5k up. save some $ for gears (4:10s) & trans also
1 Post
There's not going to be a really big difference between the two, so it's not like you're going to make a "wrong" decision with either one. Considering the fact that it's going into a K5, I'd lean toward the 6.0. You should be able to buy one for considerably less than a comparable LS1, you shouldn't have to switch away from the truck accessories (which will leave you more money for the rest of the swap stuff needed), & mod for mod, the extra 18 cubes or so will give you just a little bit more torque.
Either way, you'll probably enjoy it when it's done...
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
well i dont think its going to be the decision maker its just going to be heavier on the front end.the alum is going to run cooler i would think but thats my opinion.whats your final gearing going to be?
heres a guy thats hard up for cash right now and its a hell of a deal
https://ls1tech.com/forums/parts-cla...low-miles.html
new one are around 7k i think & u cant for get about a trans & gears. if u have an a4 might as well throw it away & buy something diff cuz if ur makeing any power @all ur going 2 tear it out.
There's an interesting thread on coloradok5.com on whether to swap a 6.0L or 8.1L into a K5 and keep it California smog legal. Here is the link:
http://coloradok5.com/forums/showthread.php?t=266215
I put a link to this exact and a couple others from this site on the very last page of the thread as well so they are cross referenced.
Scott
Scott
