2005 GTO engine ?
Old Feb 17, 2010 | 11:07 PM
dmracing's Avatar
Default 2005 GTO engine ?
What do you guys think the top end, heads and intake are worth off a 05 GTO 6 liter?
Old Feb 17, 2010 | 11:21 PM
GT-OH's Avatar
$500-$600
Old Feb 18, 2010 | 07:51 AM
zman1969's Avatar
heads should be a 243 casting - same as ZO6 but with standard valves instead of hollw stem or sodium filled exhaust - a little heavier but fine - the intake isnt worth much and it takes a 90mm throttle body the ZO6 intake still flows better with a 78mm TB. heads 4-500 is the norm
Old Feb 18, 2010 | 08:02 AM
dmracing's Avatar
So with this said. How much would this be worth?
Old Feb 18, 2010 | 08:09 AM
lizeec's Avatar
Default How Much $$ ??
Like the previous posts said maybe $400 - $600 Depending on the completeness of the manifold, does it have the injectors and fuel rails and throttle body? And the heads are they complete? How many miles on the set-up? This is like me asking you "How much would you charge me to come and paint my house?" Who Knows you have never seen my house, is it a 2 story? is it stucco? is it brick? How big is my house? You were given some general ball park figures but there is a lot of things that factor in that could change the price both up and down quite a bit. Good Luck
Old Feb 18, 2010 | 08:17 AM
WSsick's Avatar
$500-$800 area, depending on what comes with the manifold.
was there really a need to post this in more than one section?
Old Feb 18, 2010 | 11:08 AM
dmracing's Avatar
I just wanted to make sure I got enuff input. So if i sold The intake complete with throttle body and the complete heads for $550.00 that would be a deal for someone?
Old Feb 18, 2010 | 11:09 AM
dmracing's Avatar
Sorry it has I believe around 36000. miles
Old Feb 18, 2010 | 03:09 PM
Smo's04Gto's Avatar
complete 243 heads average between 400-500 by them selfs. intake use the search option should come with average cost. Good luck
Old Feb 18, 2010 | 04:53 PM
WSsick's Avatar
all of that, id say $1,000, since your the seller.
Old Feb 18, 2010 | 05:19 PM
dmracing's Avatar
I would like to just sell it at a reasonable price.
