Steam vent:
Old Mar 16, 2010 | 04:56 PM
ChrisBorsheim's Avatar
Default Steam vent:
Currently, they point to the driver side, can these be taken off and turned around to face the passenger side?
Old Mar 16, 2010 | 06:22 PM
Well, partially just answered my own question - time for a new steam valve.
What I'm trying to accomplish is this:
Using a radiator that has the inlet and outlet on the same side like the water pump to have a cleaner looking engine bay. The radiator does not have the steam valve inlet in it, so an adapter to the radiator hose has to be placed in.
Other than taking the radiator to a shop and having them drill in this hole, I was hoping to turn around the valve and point it to the passanger side so I could meet the adapter to the hose. It's a really sharp turn and will break the flimsy line - Has anyone been able to disconnect the line from the connectors and reapply?
Haven't really seen this question brought up before - nor a search result on it.
Old Mar 16, 2010 | 06:33 PM
Alright, looks like I'll be running a tap into the waterpump.
Old Mar 16, 2010 | 06:35 PM
TomM's Avatar
A picture would help.........not tracking what you are saying, mine points straight towards the radiator on the driver's side...
T,
Old Mar 16, 2010 | 11:04 PM
Yeah, it shoots off in an angle towards the driver side, however I'm opting to use a radiator with the in & out on the passanger side (matches the water pump - cleaner look) and was hoping to basically flip the design of the steam vent - basically so instead of the outlet coming out on the driver side of the throttle body it comes out on the passanger side of the throttle body since the two radiator hoses will be over there.
I'm seeing a varying assortment of steam vents so I think I'll swing over to the dealership tomorrow & see what they've got. I'll most likely end up having to tap to the waterpump.
Just trying to clean up as much stuff as I can while I've got the downtime.
Old Mar 17, 2010 | 12:28 AM
themonkeyman89's Avatar
Quick Question to those in the know, similar question:
I have an overflow stem coming off the fill neck of the radiator, can I Tee the steam vent into the line running to the overflow tank?
Old Mar 17, 2010 | 06:34 AM
TomM's Avatar
I think a truck steam line comes out on that side, and should work.
I wouldn't recommend that, there will be positive pressure at the overflow, in case of an overheat, and your cap is sealed until the pressure gets high enough for the cap to release, so no place for the steam/water to go in, that is exit only. It really needs to be in a return side of the cooling system, i.e. upper hose, or return from heater core, or water pump...
T,
Old Mar 17, 2010 | 10:01 AM
Tom's always got the answers, and so thorough too. (no sarcasm - it bothers me when people give short vague answers)
I'm going to run up to the dealership in the next day or so and see what's available.
Still deciding on the radiator. The one I'm looking at doesn't have a transcooler in it/lines so I'll have to run an external which I'm not really interested in doing. However I've seen some people mount theirs to the floor of the car? Tom, what's your thoughts on this. I think you know my mind - clean as possible - hence my discomfort for running an external transcooler.
Old Mar 17, 2010 | 10:32 AM
TomM's Avatar
I mounted my cooler underneath to the floor under the pass. seat, but don't like it. There is no room up front with the condenser. My radiator has no provision for a cooler, so that's out. I like the external coolers better, but that's just me. I had it in front of the radiator, until I remounted my A/C.. I really need to find a new place for it. Not a lot of real estate on these little cars....
Thanks for the kind words bro....just trying to keep folks from making the same mistakes I have in the past...
T,
Old Mar 17, 2010 | 11:29 AM
rojs234's Avatar
If I understand your question correctly, you want a tube that comes out on the driver side and faces forward? Here is a picture of the one on my carbed LS2 that fits that description. Problem is I'm not sure what it's off of. Probably Corvette. At least it shows that what you want is available. Hope this helps. Ron
Attached Thumbnails Steam vent:-cp42.jpg
Old Mar 17, 2010 | 02:41 PM
Exactly, mine pointed upward (toward the hood) and hard towards the driver fender making the bend too sharp to just route. Thanks for that picture.
Old Mar 18, 2010 | 08:21 PM
danbap's Avatar
this might be a dumb question but i don't know the answer, I'm guessing you are talking about that cross over tube that goes from head to head and then to the water pump? what is that exactly? and what does it do? is that all you have to do to hook it up? is there a spot on all water pumps to do that or do you have to drill and tap a whole?
Old Mar 19, 2010 | 09:42 AM
Yes, were talking about that cross over tube. It's a steam vent that allows for condensation built up in the heads to escape. Normally, there's a separate line that runs them into the radiator, but I'm optiong for a cleaner install.
Waterpump question: that's something that's been done by the guys on the forum - yes they had to run a tap for that.
Old Mar 19, 2010 | 09:50 AM
the_merv's Avatar
Veteran: Air Force
That's off of a Truck..I have a couple of them laying around.
If I was home I would send one to you.
They are not that hard to bend, try reshaping it.
Old Mar 19, 2010 | 10:13 AM
danbap's Avatar
thank you very much.
Old Mar 19, 2010 | 11:41 AM
Andy1's Avatar
Wegner Automotive makes individual steam port adapters with a 1/8NPT that allows you to plumb it any way you want.
http://s41657.storefront-solutions.c...l.aspx?ID=3289
Andy1
Old Mar 24, 2010 | 03:54 PM
markeheiden's Avatar
Hi Merv, On the pic you posted, there is a tee and on end you plumbed to the water pump but the other is just open? Can you explain where that port will go?
Also, the factory sends this "steam" vent to the middle of the radiator. Is the water pump an appropriate substitute place?
Thanks!
Old Mar 24, 2010 | 08:04 PM
javajoe79's Avatar
For the race cars I tapped those holes on the heads front and rear and plumbed then with -4 line and fittings to the coolant reservoir at the systems high point.
Old Mar 25, 2010 | 01:25 AM
the_merv's Avatar
Veteran: Air Force
Thanks!
That's not my Engine..that is just the pic that was up there..
You talkin about that one barb with the rubber cap on it? That is for the PCV System.
Where it currently is in the Waterpump is a good spot for it also.
Old Mar 25, 2010 | 09:31 AM
rojs234's Avatar
Thanks!
Just to be clear...for the newer and younger members. The picture posted of my carbureted engine shows the hose routing to the water pump. You have to tap it at this location and use various fittings to hook up the hose or braided line or whatever. Not shown, but obvious to most, you have to use some type of clamps to make it water tight. The tube sticking up from under the manifold with the rubber cap on it is, as * the_merv * said part of the PCV system (like an LS6). Since my engine is carbureted, I use a PCV valve in the driver side valve cover and a breather on the oil fill on the passenger side valve cover. Hope this makes it clear. Ron
