Power Steering Pump outputs - GTO, F-body, Corvette, CTS-V, Truck etc!
#41
This is a great old thread. I've used it many times.
Does anybody know the flow and pressure numbers for the 2010+ Camaro power steering pump?
EDIT: Got the specs, thanks to the folks at Cardone:
2010+ Camaro
Flow: 0.9 to 1.3 GPM @ 400 RPM; 1.8 to 2.2 GPM @ 1500 RPM - Flow tested at about 100psi
Max pressure: 1700 to 1850 PSI
I assume those are pump shaft RPMs, not engine RPMs. I do not know the correlation between engine RPM and pump shaft RPM. These are the speeds where Cardone tests their reman'd pumps.
Also, this pump uses the truck accessory spacing/depth.
2010+ Camaro
#42
as-reminder earlier in post
A Borgenson p/s pump pressure reducer kit was used
To reduce pressure.
I used the same kit ( cost was $17 @ Jegs )
Used 4 washers to reduce pressure on my
05 corvette pump to 800 psi
Very simple fix
Better than cutting spring
To reduce pressure.
Very simple fix
#44
Hey guys I've been trying to find this out for many months but I am getting ready to buy my GoatBuilt accessory brackets for my third gen LS Swap. For the f-body power steering pump, is it a CBR type or a TC type? Like I have said I have been searching for about 6 months but just can't find out the difference.
#46
Bumping a good old thread with a newer product finding: https://www.turnone-steering.com/col...ering-fittings
Flow restrictor instead of shimming. Check out the Tech 101 for explanation as to why. https://www.turnone-steering.com/blogs/tech-101
The following users liked this post:
G Atsma (05-09-2020)
