The Blue Lagoon - BMW e30 - LS1
Old May 14, 2010 | 12:42 PM
  #41
Blip Bavarian's Avatar
We mounted the radiator last night, and pulled the wiring harness to wrap it.
Had to cut the oem radiator mounts off to make the Mishimoto clear. This radiator could not be a better fit. It fits perfectly between the frame rails, and sets down on to the little lip in the first pic.
Im gonna run a pusher fan setup, so no need for the LS2 water pump or CTSv tensioner.
Old May 15, 2010 | 02:41 PM
  #42
IrocZTransAm's Avatar
Killer...your gonna have to bring it out around town for me to check out! I'm in Far East El Paso.
Old Jun 21, 2010 | 10:39 PM
  #43
navi243's Avatar
any updates?
Old Jun 22, 2010 | 11:35 AM
  #44
Id be happy to.
Originally Posted by navi243
any updates?
Not much lately. Painted the engine bay. Ivan?
sanded
cleaned and prepped
primed
painted satin black
added heat insulation
Old Jun 22, 2010 | 04:09 PM
  #45
violent_celerity's Avatar
i want to do this swap SOOOOO BAD!! looks awesome man. keep up the great work.
Old Jun 22, 2010 | 06:29 PM
  #46
navi243's Avatar
Originally Posted by Blip Bavarian
Id be happy to.
Yep it's me...just thought I would follow along with the build thread.
Everything looks great. Can't wait to see it done next time I go into town.
Old Jun 23, 2010 | 06:06 AM
  #47
Speedy911's Avatar
Wow that looks great. You don't have to worry about it heating up the inside of the car.
Old Jun 24, 2010 | 10:37 AM
  #48
t_raven's Avatar
Just saw this thread, this thing is bad ***
Old Jul 7, 2010 | 11:07 AM
  #49
navi243's Avatar
Any more updates Matt?
Old Jul 7, 2010 | 11:57 AM
  #50
owen v8litew8's Avatar
great work so far, I remember how hot my FC rx7 got in there so I did the heat insulation later on and on the inside which was a pita with a full interior. good stuff, this car will haul some major scoots!
Old Jul 13, 2010 | 03:26 PM
  #51
Not much... we made an adapter plate to mount the MC to the firewall, and a rod to connect the pedal and the MC. Other than that, nothing. Gonna drop the motor in for the final setup this saturday.
Old Aug 12, 2010 | 12:02 AM
  #52
Hey guys, after much delay, I have made some progress.
Added some more heat shielding out onto the firewall
Also gave my headers another coat of silicone
put in a PS delete
Nick cut me a plate to mount the MC directly to the firewall. We had to chop up and flare some donor brake lines, cause the stockers weren't long enough anymore..
then i brought the car home for the final assembly
finally got my ******* half shafts out from the hubs. It took 3 people and a monster sledgehammer
installed the new shafts
check this bs out! my powerflex bushing inverted up into the subframe. WTF?
dropped the motor/tranny in
the brake MC interferes with one of the coils. Im gonna figure out a way to remote mount the coil. More on that later.
After alot of trial and error with wiring, and with the help of my friends Julian and Brian, we got it started. Hopefully this video works...
VIDEO
More progress on the way. Thanks for looking. -Matt
Old Jan 4, 2011 | 02:06 AM
  #53
Update: Progress was slow for a while. I broke a finger on my right hand, and it was casted for 5 weeks, and useless for another 2. Ive been in the garage quite a bit lately, and with the help of some friends made some good progress! My friend Julian has been a huge help; especially with the wiring.
modified my radiator for some clearance, and so I wouldnt have to go on a search for some elaborate hoses. Both the inlet and outlet are now welded at 90 degrees. I also had Rick weld an aluminum adapter to the inlet for a coolant temp sensor
The outlet on the radiator is now 2" connection on the water pump was 1.5". I had a hell of a time finding a hose that worked, but here it is
This setup provides some decent clearance for the intake and belt tensioner considering the size of this engine bay
I then had to figure out a way to plump the steam vent back into the cooling system. I ran a line from the vent and tee'd it into a looped section where the heater lines were.
Installed this Derale pusher fan. Its only 12.5", but it moves 2150 cfm.
Also plumbed in this gorgeous overflow tank lol.
Next is started working on the gauges. I have a water temp, oil temp, and oil pressure gauge
I made a template and had Rick make me this plate for a switch pannel
the panel has a switch for my fan setup, for my gauge, and a toggle for push button start.
I also put in a 350mm Sparco steering wheel
put all the pieces of my intake together, and tapped it for the intake temp sensor. I made a support bracket out of some aluminum flat stock
Here is the engine bay as it sits. I wrapped the intake elbow in some 1500 degree insulation tape. You can also see the line for the overflow tank and the throttle cable.
I drove the car for the first time this past weekend, which was a huge milestone for me. I wanted to drive it before the new yr. The car is running really rich because I didnt have the o2 sensors connected, which fouled out the plugs. I went and bought new plugs and some o2 sensors today. I also took my y-pipe to have 02 sensor bungs added today. This week I plan on putting the y pipe back in, adding some clearance at the rear subframe for the driveshaft, and looming the wiring.
-Matt
Old Jan 6, 2011 | 08:49 PM
  #54
Tig's Avatar
Tig
Awesome build on an awesome car.
Great work.
Old Jan 8, 2011 | 10:56 AM
  #55
Kurlee Daddee's Avatar
More pics of finished product please.
Bad *** build BTW!
Old Jan 8, 2011 | 11:21 AM
  #56
renzos23's Avatar
Awesome build bro.
Can't wait to see the finished product.
Old Jan 8, 2011 | 08:22 PM
  #57
Irish350's Avatar
I cant say i wouldve gone to the lengths you did to save weight, but i guess thats the difference between a street car and a bmw-guys car
loving it
Old Jan 8, 2011 | 09:40 PM
  #58
RMB's Avatar
RMB
Default Props
I have just read through all of the posts you put into this thread... I thoroughly enjoyed it. Im lookin forward to checkin back to see the future progress.
Old Jan 10, 2011 | 07:52 PM
  #59
tbird31's Avatar
Hell to the motha freakin yeayuh. A buddy of mine had an E30 with a M50 swapped into it, that was probably in the top 3 funnest cars I've ever driven. Props man.
Old Jan 29, 2011 | 10:18 PM
  #60
C Murda's Avatar
any room for a 76mm turbo in there ??? haha im plannin on doing the same to one of my E30s...
