Anyone ever make their harness from scratch?
Not really. The important bits like the connector side and the PCM terminal are still there and clearly labeled. When using different connectors, wire colors change anyways so unless you build it yourself 100% to stock diagrams, itll never be that way. Let you in on a little secret too: OEM diagrams dont follow OEM circuits all the time. Wire colors, number in the commons, even fuse assignments arent always correct to the schematics
Most of the harnesses I build go through the firewall so only 30-50 wires need a few inches added. The rest get shortened. Truck harnesses are massively long though and even PCM extensions like the pic above can be done with minimal lengths added. IIRC that harness above was set with the PCM 7 feet from the middle of the intake. It is not typical for most swaps
Most look like this
I wish my harness looked that clean when I did it. Mine looked like a rats nest. U did a really good job.
I prefer to cut a hole under the HVAC box and hide the wiring, but some people want the longer lead for a stock type install like that one. It doesnt make any sense to me why GM made it that long
Brian
