2nd gen swap questions
Old Apr 17, 2010 | 09:58 PM
95stsrider's Avatar
Default 2nd gen swap questions
ok so im going to start on the ls1/4l60 into my 75 camaro very soon. what did everyone do as for the fuel system and wiring? im tring to do this on a 2000 budget. im pulling everything i can from my 01ss since i wrecked the car.
Old Apr 18, 2010 | 10:20 AM
Jimbo1367's Avatar
Fuel system,
Spectra Premeuim EFI gas tank $338.00 at www.rockauto.com http://www.rockauto.com/catalog/x,ca...,parttype,6268 FPR from a '02 VETTE. (local NAPA) $44.00 and use Summit pushloc FI hose and RUSSEL quick connect fittings on the FPR.
Wiring......... I am going to use www.Speartch.com
Old Apr 18, 2010 | 09:34 PM
95stsrider's Avatar
thanks for the link. im looking into the fuel lines now.
anymore suggestions keep them coming
Old Apr 18, 2010 | 11:30 PM
Camaro Ken's Avatar
That spectra tank looks like a damn good option... Wiring i went with a techrods harness. The guy up there Jeff? is pretty cool but if u go that route be sure to save yourseflf a little bit of a headache an get the vss and fan options with it. You can esily get it done for 2000 if your not going to take the motor apart at all and do your own labor however you can cause your self a few headaches if u dont replace seals gaskets oil pump and timing chanin while its out (600 bucks) and within that budget you can pick up some of those nice edelbrock longtubes from summit p/n 65073 (600 bucks) just my 2 cents
Old Apr 18, 2010 | 11:47 PM
95stsrider's Avatar
yea whats good is the car runs good and had the tranmission replaced by gm about 20000 miles ago. im going to look into those harness and the fuel set up that you suggested in your thread
Old Apr 19, 2010 | 12:39 PM
95stsrider's Avatar
ok so i found the cell im going to use since my tank is trashed. now my question is
do i run a line frome the cell to the fuel pump to the fpr to the filter to the fuel rail.
then run a return from the fuel rail to the cell? or if i use the corvette fpr do i still have a return line
Old Apr 19, 2010 | 04:25 PM
Jimbo1367's Avatar
It depends on if you have a "returness fuelrail" If you only have one fuel line going to it, you use 3/8" line from tank/cell to FPR with this fitting http://www.summitracing.com/parts/RUS-640853/ The other line on that side of the FPR is for a 5/16 returnhttp://www.summitracing.com/parts/RUS-640863/ to the tank/cell. The sole female quick connect on the FRP gets this http://www.summitracing.com/parts/RUS-640940/
then on your fuelrail..... you use this fitting again http://www.summitracing.com/parts/RUS-640853/
I plan on using this twist-tie hose http://www.summitracing.com/parts/SUM-220785-B/ with Summit twist-tite fittings http://www.summitracing.com/parts/SUM-220701-B/
Hope this helps some.
Old Apr 19, 2010 | 04:26 PM
Jimbo1367's Avatar
Oh yeah. you'll need to run a inline pump with pre & post pump filters running the cell.
Old Apr 20, 2010 | 12:44 PM
95stsrider's Avatar
cool thanks man
