Correct flexplate
You can use the dished flexplate, but you will have to oval out the holes for the converter bolts (298 MM bolt circle)
The flat 6.0l flexplate has the 300mm bolt circle like the older th400 th350, 200r4, and 700r4 used so it would be a bolt on.
will I run into any issues by modifying the holes?? Or as best practice just use a flat 6.0 flex plate and call it a day. I want to do this right the first time to avoid repair in the near future.
Thanks
With all the hours of searching and reading I can't believe that I didn't come across that posting before? I'm getting tons of good info from this site. Hopefully I'll find some good info on wiring the ECM (Me and electrical are not friends) and on the A/C system? Thanks for the help....
