g body headers
Old Apr 20, 2010 | 12:53 PM
Chevellecamino69's Avatar
Default g body headers
which did u guys end up using i was looking at headman headers any other choices?
Old Apr 20, 2010 | 11:03 PM
builder1's Avatar
I used hooker f body headers that on the pass side hit frame and had to have 1 pipe moved, drivers side fits right in. Also headers depend on your mounts or where your engine is mounted in the frame forward or back as of the stock engine placement. BRP might be the only headers made for g body with ls engine
Old Apr 21, 2010 | 02:37 AM
those are good looking headers i dont know if brp has theirs coated i now headman headers are im sort of confused on what size to get tho? i want the best performance ones
Old Apr 21, 2010 | 05:46 AM
87SS's Avatar
I've read that the pacesetters for an F-body will work. I went with the Schoenfelds on my Monte. I have my frame mounts attached to the frame 1 set of holes back from the stock SBC location (ends up being 1" back). Had to dent the firewall a small bit for the driver side. Passenger side drops right in when the motor is in, but the 1 tube hits the lower A-arm mount. I ended up cutting a portion of the mount and denting the 1 tube some and it is in. Not crazy about the 1 tube, will probably end up cutting it and routing it in as there is room.
Old Apr 21, 2010 | 12:48 PM
well i don't wan to bend my headers wouldn't mind to seat it back an inch tho
Old Apr 21, 2010 | 05:15 PM
Monte LS....1's Avatar
Seems like my buddies brp headers have a headman plate on them, but they are coated. I myself am going to use some pacesetter f-bodies and reroute the problem tube.
Old Apr 21, 2010 | 05:56 PM
LS1MCSS's Avatar
I have the BRP/Hedman headers on mine.
Old Apr 21, 2010 | 07:00 PM
87SS's Avatar
If you have a welder or know someone with one, probably one of the best moves. My headers (1-3/4 w/3.5" collectors) were $250. I think the pacesetters are right around the same price give or take. A few more bucks for some tubing and they should fit great. I just could not allow myself to spend $600+ on headers.
Not taking anything away from the guys who sell them, they look great, are coated for long life and hopefully fit well.
Old Apr 21, 2010 | 07:43 PM
spacemanspif's Avatar
When you buy the headers for an F-body, is that for a 2000+ F-body or a 3rd gen LS1 swap header (1980s)?
Old Apr 21, 2010 | 08:07 PM
87SS's Avatar
I believe they are for 98+ F-bodies
Old Apr 22, 2010 | 02:17 AM
im still confused brp sell them 600-900$ range headman sells them for 700-1200$ coated that is and im still confused on the dimensions?
Old Apr 22, 2010 | 02:58 AM
LS1MCSS's Avatar
Mine are the BRP/Hedman headers. I paid around $700, last year, for 1 7/8" coated headers. They are probably a little higher now.
Old Apr 22, 2010 | 12:27 PM
so wat the best performance dimensions to get headers
Old Apr 25, 2010 | 12:21 AM
billyflantos's Avatar
i used 98-02 f-body headers on my g-body with no problem what so ever...and that means nothing hit,i didnt have to beat on anything and they worked fine...and dont use anything smaller than a 1 3/4 primary tube header on a ls....
Old Apr 25, 2010 | 12:57 PM
What mounts are you running, billyflantos? I think I am going to use the manifolds my 5.3L came with until someone makes a better fitting product at an acceptable price.
Old Apr 30, 2010 | 11:14 PM
fastozls2's Avatar
[/IMG]pacesetter f body
Old Apr 30, 2010 | 11:16 PM
fastozls2's Avatar
[IMG][/IMG]
Old May 1, 2010 | 10:51 AM
tech1gmc's Avatar
I a '79 el camino using a ls1, and I bought the stainless ebay headers. I tried to make them work but I don't want to cut the frame to much. So, I bought brp mid-length headers that I going try.
Old May 1, 2010 | 12:34 PM
LS1DIME's Avatar
I bolted my Sanderson LS1 Swap S10 Headers on my 78 elcamino that I am swaping a 5.3 in and they fit perfect!!! I am gonna order another set for it come monday!!
Old May 1, 2010 | 09:36 PM
TURBO BUICK's Avatar
I would never buy anything again from BRP. I paid over $700 for my BRP 1 7/8 long tubes last year. A friend of mine just recently paid $589 for the same headers. I still haven't installed them so I couldn't really tell how they fit. You do need to weld the oxygen sensor bungs on them and I really am not too kean on the slip fit collectors. Oh, supposedly Phil gave me jobber price on them???? Phil if you are reading this please include a jar of vaseline with your orders. Since I still don't have them installed yet I wish I would have waited for Shawn @ RetroLsx to come out with them which I understand will be soon. By the way Shawn is a former employee of BRP. I did buy the RetroLSX oil pan and that is a very nice piece. Oh I also paid $100 dollars for Flowmaster 3" ball flanges for the collectors. For over $700 the O2 sensor bungs and the ball flanges should come already installed. Just adding my $.02 to this thread. Rich
