1998 Mustang LSx progress pics
I have to cut the passenger manifold so it will clear the sway bar.
I cut the drivers side manifold so I could use the stock power steering pump
The factory Alternator bracket from the trucks works perfectly, although it does just barely touch the hood liner. I am going to leave it as is because it is a really good fit.
Question for anyone who has installed a LS1 manifold on a truck location alternator, what did you do for idler pulley relocation?
-Garrett
p.s. - please feel free to post comments or questions.
Looks like this might be the idler pulley solution.
-Garrett
-Garrett
If it NEEDS to be modded to fit, have a spare (Gary's 68) otherwise, stay stock as you can on stuff like that.
Just my opinion... which to most people, isn't worth the electrons it took to display on your screen.
-Garrett
I needed the engine to move back 1/2" and up 1/4" or so, and it did exactly the opposite. To top it off the bottom back hole that I have to drill will likely be exactly where the metal brace is... so maybe only use 3 bolts, I will call them monday I guess and ask if I can try the mounts (drill) and if they don't work still do a direct exchange, or, maybe a refund. I hear from some people that the customer service is really good, so I am hopefully all will be well. But that just means no engine install this weekend.
-Garrett
That is what is in mine... I have another fbody pan, windage tray, pickup available if you are interested PM me
A few threads down some guy is using a stock 6.0 with stock pan with AJE lsx swap and it clears fine. See whats up. Is it possible to put it on backwards?
Heres the thread https://ls1tech.com/forums/conversio...6-0-th350.html
-Garrett
I have this pan
LS2 pan:
and this is the truck pan that fits:
I need only 1/2" clearance, so I will have to put my truck pan back on, and sell my brand LS2 pan, and buy a LS1 pan soon.
-Garrett
