ECU for drive by wire
Old Apr 24, 2010 | 07:14 PM
ajm390's Avatar
Default ECU for drive by wire
I plan on running a drive by wire setup. I currently have an 04 LQ4 with drive by wire throttle body and LS1 intake.
I realize that many vehicles did not come with DBW. Does it matter which ECU I go after? Can Non-DBW ECUs be re-flashed to incorporate it?
Thanks again,
Old Apr 24, 2010 | 08:50 PM
garys 68's Avatar
Maybe.....the easiest solution is to use an ecm, tac, and pedal that all go together.
It can get really complicated trying to mix and mafch components.
Old Apr 24, 2010 | 09:49 PM
Chevy406's Avatar
If you have an 04 PCM it should be able to control drive by wire if you reprogram it and re-pin the harness to match. Just pick a pin layout for the vehicle you are robbing the TAC and pedal from and then reprogram your PCM to match that vehicle.
Old Apr 24, 2010 | 10:20 PM
poconojoe's Avatar
The biggest question are you running stick or automatic?
Your selections will be a lot more limited if you're planning on running stick
Old Apr 25, 2010 | 03:03 PM
Anneuryzm's Avatar
Not trying to hijack the thread, but how does a manual/auto transmission effect selecting DBW components?
Old Apr 25, 2010 | 08:50 PM
poconojoe's Avatar
Because very few DBW vehicles were produced with manual transmissions, it is hard to find combinations that work
Old Apr 26, 2010 | 03:28 AM
garys 68's Avatar
I'm running an 02 truck 6.0 with DBW that came from an automatic Escalade. Bolted it to a Richmond 6 speed, no problems.
Old Apr 26, 2010 | 10:05 AM
poconojoe's Avatar
Which PCM I'm willing to bet, a 411?
Old Apr 26, 2010 | 01:38 PM
Pocket's Avatar
For GEN III, use a vette service # PCM, maybe even the tune. 0411 is popular
For GEN IV use a GTO or 10 camaro service # PCM
Main thing is to make sure your PCM is DBW compatible, then match your harness pinout to the PCM and use a matching TAC module
Old Apr 27, 2010 | 12:42 AM
garys 68's Avatar
No idea, what comes on a stock 02 Escalade LQ9?
Old Apr 27, 2010 | 12:23 PM
poconojoe's Avatar
It would have come with a 12200411, which seems to be the best one to get a stick shift to work with
Old Apr 27, 2010 | 01:09 PM
garys 68's Avatar
Woohoo, the one dumb luck aspect that worked out for me on this swap
Old Apr 30, 2010 | 08:32 AM
ajm390's Avatar
So, from what I gather, it would be wise to search for the 12200411 PCM.
This PCM has the hardware to drive the IAC on cable throttle bodies, and can be used for DBW throttle bodies, depending on the firmware installed.
Can anyone confirm this?
