Use baffle with S&P pan?
Old Apr 27, 2010 | 04:30 PM
AustinYukon's Avatar
Default Use baffle with S&P pan?
I had an LH8 setup on my motor but finally bought a modified fbody pan. When I removed the LH8 pan, I left the baffle bolted to the motor.
I haven't started the motor yet and have not tightened everything. Do I need to remove the baffle and just mount the oil pan?
Old Apr 27, 2010 | 04:34 PM
bczee's Avatar
When you say Baffle.. are you referring to the Windage Tray as it is commonly called (or a defector as GM calls it).?
usually the F-Body pan will require a 3/4 length one.. as the front of the F-Body pan is very close to the block and rotating assembly.
If you using the LH8 one, it should be a full Length one. you can cut it down to the 3/4 Length ok if you need to.. and you should be ok.
Old Apr 27, 2010 | 05:18 PM
Haha I had typed windage tray then went back and retyped baffle. I'm tired.
Hmmm ok, Is there any pics or specs to show where I would need to cut it?
Old Apr 27, 2010 | 05:50 PM
adrian-1's Avatar
Here's a post with detailed pictures.
https://ls1tech.com/forums/conversio...1-oil-pan.html
My swap is a 06 GTO LS2 into a 68 Camaro. I'm still waiting on my S&P modified oil pan to arrive. I'm in Austin too! Goodluck with your build.
