4L60e questions
Old May 8, 2010 | 10:02 AM
1976CamaroGuy's Avatar
Default 4L60e questions
Ok, I have I a 2004 Vortec engine and I picked up a late 4L60e and was told it was from a 1999 Astrovan 4.3 (I think).
The casting on the case is 24207965 and it the bellhousing will physically bolt up to the engine (2-piece bell and six bolt tailshaft).
My question is will this tranny work with the Gen III engine and bolt up fine? Or will I need to modify / adapt something to get it to work? I'm scared that the astrovan was a gen II engine and something is different.
If there is some modifying involved please post in here, I tried to search and it's a pain to look through thousands of threads just for an answer like this.
Thanks in advance
Old May 8, 2010 | 10:16 AM
gofastwclass's Avatar
You would have to know if the Astro was a V6 or V8. If it was a V6 you will need the spacer from GM or other sources, if it's an 8 bolt her up and have a good day! The V6 crank spacing is the Gen I / II style and thus .400" shorter than the Gen III input.
The two piece case with the six bolt tail shaft is the late 1996 / 1997 or newer case but the input side is different from V6 to V8.
Hope this helps.
Old May 8, 2010 | 10:23 AM
It was a 4.3, here is the picture if the output shaft - Thanks for the quick reply
Old May 8, 2010 | 10:29 AM
Then you need the GM spacer and six longer bolts for the flex plate. You may have to elongate the three holes for the torque converter in the flex plate slightly because they won't line up.
The GM part numbers are 12563532 and six of 13563533. Total cost should be about $80 from your local GMPP dealer or if one isn't near, Skoggin Dickey (site sponsor). I'm lucky enough to be able to source locally and save on shipping.
Remember the bolts that hold the trans and engine together are metric so you may well grab some of those while you are there or stop at the hardware store before going home.
Old May 8, 2010 | 02:48 PM
thanks for the info, so if I was to buy a new higher stall torque convertor then I would need to locate one for a pre-97 4L60e or 700r4 with the older input shaft?
Old May 8, 2010 | 05:52 PM
Hey is the 13563533 part number for the bolts correct? I tried to look on gmpartsdirect, jegs, and even a google search and it comes back as a bad number.
Old May 8, 2010 | 07:55 PM
sschevyss's Avatar
Looks like you doing a conversion. Are you keeping your 5.3 stock? just curious as to what mods you will be doing to the tranny if any? I am in the process of building my LS motor now and will be doing tranny next.
Old May 8, 2010 | 08:09 PM
Internally my engine is stock, I added a Ls1 Intake and bracketry for hood clearances.
Mu tranny is stock as well, but I did install a corvette servo this morning and will most like put in a higher stall torque converter.
Old May 8, 2010 | 08:35 PM
This is another trick... You need a "newer" style torque converter because the computer needs to talk to the torque converter clutch in a different way than the older 700R4 style. One of the differences between the transmissions is the PWM on the front pump. PWM is for Pulse Width Modulated where the older style transmissions use a on / off lockup converter. The newer style supposedly locks up smoother than the original style. Beyond that I don't know all the technobabble, I've just been told they aren't interchangeable.
12563533
is the correct part number. I miskeyed that one, sorry.
Old May 8, 2010 | 10:23 PM
sschevyss's Avatar
Why the Corvette servo? What is the benefit of adding this? Also what size stall converter are you going to go with?
Old May 9, 2010 | 06:45 AM
Using a corvette servo is a cheap, popular mod for a firmer shift and holding power. I got my servo off eBay for $19.95 shipped.
http://www.gmfullsize.com/forum/showthread.php?t=1159
http://www.greatlakes4x4.com/showthread.php?t=117743
Not sure on the stall yet, maybe something in the 2000 - 2400 range, nothing too crazy but little more than stock.
Old May 19, 2010 | 03:17 PM
Got my spacer and bolts today, I was wondering...I can still re-use my 5.3 vortec flywheel against the 4L60e tranny? But I would still need to enlongate the bolt holes correct?
Old May 19, 2010 | 07:38 PM
It has worked for me for around 10,000 miles so far... I guess that would be the long version of "yes."
Depending on the converter I would wait and see if it needs to be modded. I used my converter as a template and it didn't take much.
Old May 22, 2010 | 04:09 PM
I'm trying to bolt er back together right now, I have the spacer installed and noticed that the torque converter get's in a bind if I try to tighten it up.
I've been through the "make sure the TC is seated" scenerio before, lets just say for arguments sake it is......is it normal for the tc to be tight? or should there be a gap between the flyhweel and TC when the tranny is bolted in place?
I'm just concerned about mixing and matching parts and I could be have some clearance issues....I loosened the bolts and pryed the tranny back 1/8" and the TC is spinning freely now.
Old May 23, 2010 | 10:27 AM
The TC should be able to spin freely when the trans is bolted to the back of the engine. You can (for test purposes obviously) run the engine without the TC attached to check for vibrations and such (done it) by unbolting it and sliding it all the way back into the transmission.
In your scenario something isn't quite aligned properly. Did you test-fit slip the nose of the converter in the adapter before you assembled everything? Is the transmission going on straight? I've gotten over zealous and started bolting up the trans only to realize it wasn't straight and had a similar issue. One last thing... do you have the alignment dowels in the block? That will cause all sorts of havoc if you don't.
Old May 23, 2010 | 05:25 PM
Jimbo1367's Avatar
If I recall correctly, the 4L60 have more than one click to set the TC unlike older trans. MAYBEE the problem. Try turning it while pushing in lightly. Just a thought.
Old May 23, 2010 | 08:23 PM
biggeazy-e's Avatar
might be a little off topic, but- a guy locally has an 04 2wd v8 4l60E with about 113k on it for pretty cheap, I was wondering if it might be a safe buy to freshen up and run w/o rebuilding..
I pulled the dipstick and the fluid looks clean, but that's pretty much it.. didn't know if there were many issues with these trannys, option is either something along these lines or saving up a little more and going with a rebuilt unit.. any input/advise is appreciated.
(I've rebuilt th350s in the past with success, ripped apart 700s, but never an actual rebuild on one)- no longer have access to as many transmission tools as I did a few years ago
