99 Corvette Wiring Harness
97-98 PCM and harness are not interchangeable with 99-newer.
99-02 PCM and harness are interchangeable, but 99-00 has EGR.
this little magnifying glass / holder from Harbor Freight really helps with soldering:
relay box from Current Performance along with split mesh loom from Ebay:
98's also have a ground loop from red to blue, so if you've got no wires crossing directly from one connector to the other, its a 99+
One other question, HP tuners can flash the pcm, delete vats etc to make it work as a swap stand alone system correct?
Also what would be a good deal for one of these? (seems like from what i have seen they go for anywhere from $60-140)
