2004 GTO PCM and Truck VSS: Compatible?
My truck VSS sensor has two wires and the 2004 GTP pin-out suggests only one signal wire. Any suggestions on how to wire this?
Thanks.
Thanks.
Its pins 20 and 21 on the green connector
Connector Part Information
PCM Connector C2 92231110
80-Way Micro-Pack 100W Series Sealed (GN)
Pin
Wire Color
Circuit No.
Function
1
BK/RD
450
Ground
2
BN
418
TCC PWM Solenoid Valve Control
3-5
Not Used
6
RD
1228
PC Solenoid Valve High Control Sol.A
7
Not Used
8
GY/BU
1229
PC Solenoid Valve Low Control Sol.A
9
GN/WH
465
Fuel Pump Relay Control Primary
10
BN
121
Engine Speed Signal - Tachometer
11
Not Used
12
GY/BK
1687
Ignition Retard Signal, from EBCM
13
Not Used
14
GN/BK
380
A/C Refrigerant Pressure Sensor Signal
15-17
Not Used
18
GN
59
A/C Compressor Clutch Supply Voltage
19
Not Used
20
TN
1231
AT ISS Low Signal
21
BU/WH
1230
AT ISS High Signal
22-23
Not Used
24
BU
411
TP Sensor Signal
25
BN
472
IAT Sensor Signal
26
WH
2121
IC 1 Control
27
YE
2127
IC 7 Control
28
L-GN
2126
IC 6 Control
29
WH
2124
IC 4 Control
30
Not Used
31
BN/WH
492
MAF Sensor Signal
32
L-GN
432
MAP Sensor Signal
33
BU/WH
473
High Speed Cooling Fan Relay Control
34
GN/YE
428
EVAP Canister Purge Solenoid Control
35-38
Not Used
39
WH/BK
631
12-Volt Reference - CMP Sensor
40
BK/RD
450
Ground
41
Not Used
42
GY/RD
422
TCC Solenoid Valve Control
43
L-GN/BK
459
A/C Clutch Relay Control
44
YE
1652
Reverse Lock Out Solenoid Control
45
WH
1310
EVAP Canister Vent Solenoid Control
46
BN/WH
419
MIL Control
47
YE/BK
1223
2-3 Shift Solenoid Valve Control
48
L-GN
1222
1-2 Shift Solenoid Valve Control
49
Not Used
50
PU/WH
5197
VSS Signal
51
YE/BK
1227
TFT Sensor Signal
52
L-BU
1150
HO2S Bank 1 Sensor 2 Heater Control
53
RD/WH
1350
HO2S Bank 2 Sensor 2 Heater Control
54
PU
30
Fuel Level Sensor Signal
55-56
Not Used
57
GN/OG
5514
Low Reference - IAT Sensor and A/C Refrigerant Pressure Sensor
58
BN/WH
331
Engine Oil Pressure (EOP) Sensor Signal
59
Not Used
60
BN
2129
Low Reference - Ignition Coils Bank 1
61
PU
2130
Low Reference - Ignition Coils Bank 2
62
GY
773
Transmission Range Switch Signal C
63
BN/YE
1224
Transmission Fluid Pressure Switch Signal A
64
D-GN
890
Fuel Tank Pressure (FTP) Sensor Signal
65
Not Used
66
L-BU
2128
IC 8 Control
67
YE/BK
2122
IC 2 Control
68
GN
2125
IC 5 Control
69
BU
2123
IC 3 Control
70-71
Not Used
72
BK/WH
1050
HO2S Bank 1 Sensor 1 Heater Control
73
Not Used
74
L-GN/RD
1250
HO2S Bank 2 Sensor 1 Heater Control
75
Not Used
76
L-GN/WH
1749
IAC Coil B High Control
77
L-GN/BK
444
IAC Coil B Low Control
78
L-BU/BK
1748
IAC Coil A Low Control
79
L-BU
1747
IAC Coil A High Control
80
Not Used
Pin
Wire Color
Circuit No.
Function
1
BK/RD
450
Ground
2
BN
418
3-5
Not Used
6
RD
1228
7
Not Used
8
GY/BU
1229
9
GN/WH
465
10
BN
121
11
Not Used
12
GY/BK
1687
13
Not Used
14
GN/BK
380
15-17
Not Used
18
GN
59
19
Not Used
20
TN
1231
AT ISS Low Signal
21
BU/WH
1230
AT ISS High Signal
22-23
Not Used
24
BU
411
TP Sensor Signal
25
BN
472
IAT Sensor Signal
26
WH
2121
IC 1 Control
27
YE
2127
IC 7 Control
28
L-GN
2126
IC 6 Control
29
WH
2124
IC 4 Control
30
Not Used
31
BN/WH
492
MAF Sensor Signal
32
L-GN
432
MAP Sensor Signal
33
BU/WH
473
34
GN/YE
428
35-38
Not Used
39
WH/BK
631
40
BK/RD
450
Ground
41
Not Used
42
GY/RD
422
43
L-GN/BK
459
44
YE
1652
45
WH
1310
46
BN/WH
419
MIL Control
47
YE/BK
1223
48
L-GN
1222
49
Not Used
50
PU/WH
5197
VSS Signal
51
YE/BK
1227
TFT Sensor Signal
52
L-BU
1150
53
RD/WH
1350
54
PU
30
55-56
Not Used
57
GN/OG
5514
58
BN/WH
331
59
Not Used
60
BN
2129
61
PU
2130
62
GY
773
63
BN/YE
1224
64
D-GN
890
65
Not Used
66
L-BU
2128
IC 8 Control
67
YE/BK
2122
IC 2 Control
68
GN
2125
IC 5 Control
69
BU
2123
IC 3 Control
70-71
Not Used
72
BK/WH
1050
73
Not Used
74
L-GN/RD
1250
75
Not Used
76
L-GN/WH
1749
77
L-GN/BK
444
78
L-BU/BK
1748
79
L-BU
1747
80
Not Used
Do you happen to have a yellow 944? Mine is coming painfully slow. I have the suspension put together but waiting on the motor to go in the car. Just waiting on parts and it is killing me. I thought I would be done by now. So, to pass the time I am starting the wire harness.
