Need idea for longtube headers...XR4ti...seriously.
Only one other person I know of has installed an LS-series engine in a Merkur XR4ti. I'm planning this swap as we speak and need some idea as to what headers I should attempt to fit to the car.
Areas of fitment concern are primarily :
-Steering shaft
-Over the front swaybar(its a firewall mounted swaybar, it doubles as a compression strut for the front suspension....There is aworkaround if I cant keep the swaybar with headers, but its aobut 500 extra dollars
-Also of course there is floor pan clearance. I would attempt F-Bodyh headers but I think it kicks out to the side too much on the driver's side.
I will be using a T-56 or TKO trans behind the engine.
Anyways here are a BUNCH of pics of the other guy's swap that will help I think with suggestions.
Here is apic from the passenger side front corner. The gold colored fat tube toward the trans tunnel is the swabar/chassis brace.
http://www.merkurtech.com/merkurtech...install003.jpg
Here is a fron drivers view. You can see the steering shaft and the swaybar again in this picture.
http://www.merkurtech.com/merkurtech...install004.jpg
Here is a pic from the front of the passenger side mount he made. You can see where the exhaust would route to if you look under the car a bit.
http://www.merkurtech.com/merkurtech...install013.jpg
another view from the passenger side.
http://www.merkurtech.com/merkurtech...install014.jpg
Passenger side mount from top dow to show some clearance possibilities...
http://www.merkurtech.com/merkurtech...install015.jpg
Drivers side with a factory LS2 manifold and its clearance to the steering shaft/crossmember
http://www.merkurtech.com/merkurtech...install016.jpg
A good view from behind drivers front tire showing swaybar. You can see the bellhousing just barely clears it.
http://www.merkurtech.com/merkurtech...install020.jpg
Here is Passenger side with manifold and converter in place.
http://www.merkurtech.com/merkurtech...install021.jpg
Self explanatory view from drive tunnel
http://www.merkurtech.com/merkurtech...install036.jpg
View from end of trans
http://www.merkurtech.com/merkurtech...install034.jpg
Empty engine bay with trans.
http://www.merkurtech.com/merkurtech...install032.jpg
Any help or info is appreciated!
-Steering shaft
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Looks like you have plenty of room, but I don't think anyone has done this car yet. I'd look for a set of 302/351 headers, get a pair of LS flanges, and just see where you need to make changes.
