LS1 Camaro Power Steering Pump fittings.
I have searched and searched and searched... But I have not been able to find out what thread goes in the power steering pump (pressure side).. I am trying to make up some braided lines.. I have the p/s box fittings all figured out, but the pump is stumping me.... I see alot of people use the stock hard line and cut it off and add to it with a compression fitting, but I would like to run new braided the whole way.. Appreciate any help.. Thanks! Jason.
This is what you want.
http://www.jegs.com/i/Russell/799/648060/10002/-1
Also do not use normal stainless braided line it will fail in time. You need something rated for a much higher pressure.
Needs to finish car
I've got a hyrdoboost from Hydratech on the Camaro, and it came with fittings and hoses to adapt to the PS pump. It had these brass inserts that allow you to use a 5/8-18 45* flare fitting instead of the o-ring fitting:
![](http://www.hydratechbraking.com/products_old/_misc/9106.jpg)
This way there is only one fitting screwed into the pump rather than having to use the adapter fitting and then a -06 AN. It makes for a little cleaner install. A pair like is shown in the picture runs $10 from them.
Sounds like your on the right track with the Aeroquip Teflon hoses. They worked great for me.
Needs to finish car
Damn it man!! I wish I would have seen that earlier!! haha.. Oh well, I can always change it out later... I actually have lee mfg. inserts in my steering gear that accomplished the same thing. They work great.. I had no idea they made those for the pump as well.. One other question.. Did you use teflon hose for your return line as well? I bought enough to do both lines with the teflon, but I am having a HELLLLL of a time getting the hose stretched over the barbed nipple on the reservoir.. Plus being plastic, I'm trying to be careful and not snap it off :-( Any tricks for getting the hose to slide on easier?? Thanks again for all the useful info!
I took my LS1 hose end, the steering box hose end, and a piece of wire bent like I needed the hose ran over to the NAPA store last week. About 30 minutes later and $32 lighter, I had my hose to go on my LS1 76 Camaro.
For the return line on my LS1 pump I cut the bead off the plastic tube, sanded it slightly and put a 3/8 compression (Swagelok) to AN fitting on there and ran the braided line. Just wanted it all to look the same.
You might be a little late. This thread ended 8 years before your reply.
