The OFFICIAL X-Body Swap Thread
Old Sep 5, 2010 | 03:27 PM
-TheBandit-'s Avatar
Here's one to add to the list:
https://ls1tech.com/forums/conversio...l80-build.html
Old Sep 13, 2010 | 12:18 PM
https://ls1tech.com/forums/conversio...00-6-0vvt.html (-TheBandit-)
Mounts TBD
Oil Pan TBD
Headers TBD
Old Sep 17, 2010 | 12:11 PM
Chevy406's Avatar
Decided to start a build thread for my '69 Nova. Maybe you guys can help keep me motivated to make progress.
69 Nova 408 twin turbo build
Old Sep 23, 2010 | 08:24 PM
Thanks to John B for gettign this into the stickies!
https://ls1tech.com/forums/conversio...ml#post8168556
Old Oct 17, 2010 | 06:31 PM
usafws6's Avatar
Were are you guys getting your driveshafts from?
Old Nov 7, 2010 | 01:05 AM
bczee's Avatar
Well finally got around to starting my thread.. 71 Nova, using a LS1, 4L60E and the brakes from a 02 Z28 Camaro
Cleaned up the motor some
ARP Rod and Head Bolts
Freshen up the Heads, added Comp 918's spring, Retainer and push rods
Comp Cam - ***** Thrumpr
Complete Hotchkis TVS
Edelbrock Headers
Fab'd up some mounting plates.. used Edelbrock pattern. 1" setback out of 1/2" Alum. Energy Suspension Short/Wide mounts. (moved Frame mounts 1/2" forward due to trans tunnel and firewall clearance (too tight).
https://ls1tech.com/forums/conversio...02-ls1-a4.html
Old Nov 23, 2010 | 10:14 AM
Originally Posted by hookemdevils22
1970 Nova LS2/T56 (another thread here) (strtlegal)
Mounts AutoKraft
Oil Pan AutoKraft
Headers StainlessWorks
This info isn't right. From his thread:
Originally Posted by strtlegal
Thanks guys, Ive got Brp motor mounts and the first production set of 1 7/8" headers from them as well..I'm running an LH8 oil pan which clears very nice but does hang low, we will see how close it gets to the ground once I lower the care back down..
Old Nov 23, 2010 | 10:23 AM
hookemdevils22's Avatar
That's old. Chuck sold off his BRP stuff and went with the AK/SW setup instead.
Old Nov 23, 2010 | 10:56 AM
Good to know, thanks!
Old Jan 3, 2011 | 12:54 AM
frojoe's Avatar
Maybe accessory drive should be a field as well? I've gotten the most PM's regarding the truck acc drive and whether or not it'll fit a stock hood... just a thought to make the 1st post in here just a bit more comprehensive!
-Joe
Old Jan 4, 2011 | 10:00 AM
updated with what I could find. FYI - the truck stuff DOES fit under the x-body hood with standard mounts.
Old Feb 1, 2011 | 10:57 PM
  #32
1972nova's Avatar
my 1972 nova build
https://ls1tech.com/forums/conversio...lsx-build.html
Mounts Ebay 1" setback
Oil Pan LH8
Headers W Body 5.3 manifolds for turbo app
Accessories fbody/custom
Old Apr 7, 2011 | 08:04 AM
  #33
1972nova's Avatar
you can change mine to
Ebay mounts 1" setback
Autokraft Oil Pan
Stainless works up and forward headers
Accessories Fbody/custom
Old Apr 18, 2011 | 04:39 AM
  #34
usafws6's Avatar
ive got some brp nova conversion mounts in the for sale section for cheap
https://ls1tech.com/forums/parts-cla...arts-misc.html
Old Jun 13, 2011 | 06:14 AM
  #35
bitterman's Avatar
1968 Chevy II Nova
Mounts Not 100% sure If I use Dougs headers, I'll use their matching mount.
Oil Pan Autokraft
Headers Dougs Headers
Accessories Kwik Performance
Hooker BlackHeart Transmission Crossmember Part # 12627HKR
Finally getting back at the car.
Old Jul 6, 2011 | 09:23 AM
  #36
1968 Chevy II Nova Carb'd LY6 (bitterman)
Mounts Doug's Headers
Oil Pan Autokraft
Headers Doug's Headers
Accessories unk
Hookemdevils22, the link is missing on this one. Here's the URL:
https://ls1tech.com/forums/conversio...1968-nova.html
Old Jul 6, 2011 | 09:28 AM
  #37
gocha updated. thanks clint
Old Jul 6, 2011 | 09:37 AM
  #38
1970 Nova LY6/TH400 (-TheBandit-)
NOTE: Retaining VVT
Mounts TBD
Oil Pan TBD
Headers TBD
Accessories GM L99, w/ AC
NOTE: Retaining VVT, clearanced frame for low mount AC
Mounts Custom 1" lift 1/4" forward
Oil Pan Autokraft
Headers Dougs D3337
Accessories LS3 intake, GM L99 wp & ps, TBSS AC
Old Jul 6, 2011 | 09:47 AM
  #39
updated. also linked to your accessory notes and mount design. anything else?
Old Jul 6, 2011 | 10:44 PM
  #40
dsster's Avatar
Man I Wish I have time to write up a build thread on my car but here is mine as it sits. car is 1970 nova ss. its ready to fire up this weekend just need a custom driveshaft to run it. here are some pics
this is the best part of the car 345 30 18 in the rear.
