72 Nova LQ9 alternator relocation?
It does not look like my hood is going to be able to close. The alternator is too high. I am not ready for the hood to be on yet, but wanted to get some ideas of what I might have to do. I think I have read that there are some relocation brackets. I did not know which one would work. The other option is a cowl hood. I think I would like to keep the stock hood. Does anyone know which alt bracket works and where to get it?
Thanks
Thanks
the lq9 in my trans am has the alternator on the bottom right side of the engine. i think mine was relocated when i bought it. but you can get it off of any local store like autozone or etc. i just replaced my alternator and when i bought it they bracket came with it so im pretty sure they cary them anywhere and you just have to ask if its the stock bracket or the relocated one. let me know what you find out please.
Do you have a stock steel hood? I know that I originally thought that the alternator would for sure hit my hoood, but it didn't, it actually even had 3/4" clearance... looks can be deceiving! I would recommend just mocking the hood on there before you decide to buy a (likely costly) relocation kit or different accessory drive...
I have read about someone cutting the stock truck bracket to make it work. I am still a few weeks before i will be mocking it up.
Frojoe, are you making any progress?
My comment was assuming that the LQ4 & LQ9 have the bracket as well as alternator (I don't know why they wouldn't)... I thought the corner of the alternator would hit or the throttle body top would hit, but turns out the only thing that prevented the stock steel hood from closing was one of the the plastic mounting bosses for the engine cover.
I zipped about 1/2" off the top of the boss at the front of the intake (completely removing the brass insert portion) and the hood closed, didn't even need to bang or trim the cross-braces underneath the hood!
As for my build, I've made some mental progress, and have a few things up my sleeve that you all can watch for hopefully in the coming weeks...
Cheers,
Joe
Cheers,
Joe
I am not sure what engine mounts you are using but some position the motor higher in the engine bay than others. If you run into clearance issues with the stock brackets it may mean your set-up sits higher than frojoe's.
I have a LQ4 in my '72 Nova and I went with the Kwik Performance set up. It is exactly what I wanted and was way cheaper than anything else available. It lines up with the truck pulleys and water pump and if you ever want to add A/C it is a separate bracket he sells. Additionally if you ever change to an LS intake and water pump you just replace the spacers in between the brackets and it repositions everything to the correct depth (rather and having to buy all new brackets).
I have ample clearance with my hood. My PS pump runs a different size pulley so belt selection took awhile but it comes with suggested lengths that should work.
I ended up getting a cheap 2001-05 s-10/sonoma/jimmy/bravado alternator. It fits perfect and is about 2" shorter than the one off the LQ9, but it has a 4 plug connecter vs the 2 plug on my harness. My buddy said this can still work. I wanted know if anyone else has done this, and how did they wire it??
Thanks
Thanks
1972, 53, 60, alternator, bracket, com, comnospacebefore, lq4, lq9, ls1, nospacebefore, nova, power, relocation, steering
