Help identify ports on intake and throttle body!
First picture is the port on the drivers side on the intake right behind the throttle body... What hooks up to this?
Second picture is on the drivers side on the TB/intake. the line coming off the steam vents from the heads, the hose that was on the line lead directly to the port on the throttle body, is this correct to hook the hose up there?
Third picture is a port coming off the throttle body, what does this hook up to?
Last picture has two ports that i need identified...
I also have yet to hook up my wastegate and BOV vacuum lines so if they can hook up to any of these open ports please let me know. This is my first LS conversion and the first time i've ever messed with turbo stuff so i'm getting to the point where i need the extra help....
Thanks in advance!!
Second is the steam tube going through the TB. If you dont live in the arctic circle you can remove the short hose and cut the ports off the TB. After the first time you bust knuckles across them youll do it anyways. The steam tube needs to get plumbed into the cooling system somewhere. Do a search, theres tons of solutions
Pass intake/TB ports
Upper is metered air into the crank case. Pass side valve cover, front port
Lower on the intake is return. LS1 Fbody's have two ports, one on each valve cover with the inline PCV. Trucks have one port at the rear of the drivers valve cover at the PCV
The 2nd and 3rd are the steam vents you referred to. Just leave the in and out from the throttle body open. The part of the hose with the factroy squeeze clamp is where you attach the hose that will go to the jagsthatrun "T".
That will let you purge the air bubbles from the head, directly to the return of the radiator.
On the last picture, 1 is the vacuum source for the PCV system and 2 is the fresh air source for the PCV. You can either hookup the PCV hoses and use it as designed, or cap them and go to valve cover breathers.
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Are any of these ports able to be used for my BOV or wastegate vacuum lines?
thanks for all the help so far btw!!
