Best way to put coolant in system?
Exists any procedure for this?
I reccomended this for another guy here... I have never had any problems:
try this bro....... after you fill the block completely...
rock the car a bit.... you may even hear or see a few bubbles...
then fill the radiator...
start the car, with the rad cap off and let it run a bit and get warm...
If the coolant is not running through the radiator... get in the car and rev it slightly, with the cap off, now some coolant may bubble out but that usually works that air pocket out.... now don't rev it through the roof.... and let it run a bit with the cap off until you see coolant running through the radiator.... When it starts running, the coolant level in the radiator probably will drop a bit... when it drops and you have running flow, fill the radiator to the top or the desinated coolant line ....
Also I lay some towels around the filler cap so I don't get coolant on my battery, it will make a little mess but it should get the air pocket out... What some guys do also is stick the funnel in the filler cap location on the radiator and the air pockets bleed and bubble inside the funnel......
remember the air pockets usually always go to th highest point of the system.... I have sat and watched tons of cars when I ve done radiator changes or coolant changes etc... and you would be surprised of the air pockets in the system...
Now with my BBC I would always drill 3 1/8th holes in the t-stat to work as a bypass to burp the system.... Down side is when it is cold, it takes a little longer to warm up... But works almost like a failsafe, you'll always now coolant is flowing
http://buy1.snapon.com/catalog/item....re&dir=catalog
Removes most of the air by pulling a vacuum on the cooling system, then when you are confident the cooling system has sufficient vacuum ~25 inches and holds it steady you open a valve and the vacuum now pulls the coolant into the engine. Seems to stop at about 2 gallons the first time which is enough for initial startup, or you can pull another small vacuum and get the rest in.
