TCC Wiring
Old Oct 5, 2012 | 10:05 AM
ls1nova71's Avatar
Originally Posted by psiconversion
Just an FYI out there, PSI sells a kit for this, includes a pigtail, instructions and the switch for $16.99.
Jon
PSI
What kind of switch does it come with?
Old Oct 5, 2012 | 10:19 AM
aknovaman's Avatar
I like to use mid 1980 monte Carlo 4 pis brake switch. They came on almost every gm car.
https://ls1tech.com/forums/conversio...2-cutlass.html
Old Oct 5, 2012 | 11:18 AM
1936 LS1's Avatar
That style of switch wouldn't work in my application but still good info for other swaps. Mine is under the floor like ls1nova71's in his '33
Old Oct 5, 2012 | 08:20 PM
psiconversion's Avatar
LS1Tech Sponsor
We use a two position switch with the correct pigtail and instructions.... see link...
http://secure.ultracart.com/catalog/.../KIT-1002.html
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Oct 6, 2012 | 03:30 PM
bakomack's Avatar
I'm doing a lsx in a 1988 foxbody.
I pretty much understand the tcc wiring using the relay to ground power when pedal is pressed.
But what about the stop lamp switch?
Is it a constant 12v like the tcc that needs to be grounded when brake is pressed?
Cuz there is a little white tab on the wire that says "gets 12v when brake is pressed? I wired it to the brake pedal wire that gets power when pressed but my converter isn't disengaging.
Can anyone draw up a diagram for what I need to do?
Old Oct 6, 2012 | 04:49 PM
ls1nova71's Avatar
Im a little confused about your use of the word grounded. You don't want to ground power ever. The switch is either open or closed. Open power is cut off and closed it is on. The TCC needs power with the brakes NOT applied, just the opposite of the brake lights. What kind of switch are you using?
Old Oct 6, 2012 | 05:55 PM
bakomack's Avatar
The stock mustang brake light switch. I just tied the wire into the wire which has no power until pedal is pressed.
Old Dec 28, 2012 | 01:38 PM
Friday13th's Avatar
Default Other wires
Could someone help me with my brake switch? I am not sure where the:
pink wire in A blue connector and
grn/wht in B blue connector connect
Gray connector
(A) orange wire +12V
(B) lt blue wire goes to tail lamps
Blue connector
(C) pink wire to ignition fuse
(D) purple wire TCC to blue PCM 33
Old Dec 28, 2012 | 06:25 PM
ls1nova71's Avatar
Gray connector
Blue connector
Those are the 4 wires you need. Without knowing exactly what the switch is from, my guess is the other 2 wires are going to be for the shift interlock (press on brake pedal to shift from park).
