how long - balancer installer
Old Jul 8, 2010 | 06:26 PM
Jimbo1367's Avatar
Default how long - balancer installer
I was wondering how long of a piece of 16mm x 2.0mm allthread do I need to install a LSx balancer (LY6)
thanks,
Jim
Old Jul 8, 2010 | 06:30 PM
Rick Speed's Avatar
mines about 10" long but it doesn't need to be
Old Jul 8, 2010 | 06:47 PM
Jimbo1367's Avatar
I am wondering how long should be the minimum in length? I am on vacation so I can not measure it. I was hoping to find out and order it so it will be delivered before I get home.
thanks,
Jim
Old Jul 8, 2010 | 07:19 PM
Pocket's Avatar
Get longer than necessary and cut it down later. What works for some people wont always work for others, especially with improvised tools like this
Old Jul 8, 2010 | 07:30 PM
Jimbo1367's Avatar
thats my problem. I am having a hard time finding it. I have found fully threaded bolts. Up to 150mm. I just need a minimum though. I will have to wait longer for threaded rod. WHich I don't want to do.
thanks,
Jim
Jimbo1367's Avatar
thanks,
Jim
Old Jul 9, 2010 | 06:30 AM
97s10ls's Avatar
Try Mcmaster-Carr that place has everything. They have it web site is pretty easy to navigate also
Old Jul 9, 2010 | 06:58 AM
flame's Avatar
I got an ARP bolt for the crank and it is long enough to pull it on
Old Jul 9, 2010 | 11:36 AM
Jimbo1367's Avatar
does this bolt engage the threads much? I would think if it does, it would "bottom out".
thanks,
Jim
Old Jul 9, 2010 | 11:54 AM
bczee's Avatar
I just needs to be about and 1" to 2" longer than a stock balancer bolt. I found a bolt that was about 5" that worked with my LS1 balancer. Might need a bit longer one for a Truck Balancer?.
Remember to use a few washers and some grease to help make it turn a bit easier.
Old Jul 9, 2010 | 12:01 PM
Jimbo1367's Avatar
Default McMAster-Carr
Thanks. I always forget to check them. My order was just placed. I wish they'd show shipping charges though. I hope my shipping doesn't equal the rod & nuts price.
thanks,
Jim
Old Jul 9, 2010 | 12:20 PM
Jim_PA's Avatar
I just warmed it up with a propane torch and slid right on by hand.
You could probably boil it in a pot of water and get the same result.
Old Jul 9, 2010 | 01:04 PM
Jimbo1367's Avatar
thats a idea too. LOL. I should of thought of that concidering us Sea-Doo guys always put our wear rings (jet-pump) in the freezer prior to installing them.
Once I am home from vacation, I will install the balancer and sell whatever I have left from my threaded rod/nuts for people who don't want to spend $45.oo from the LS1/tools member.
Old Jul 12, 2010 | 11:33 AM
flame's Avatar
thanks,
Jim
It has a thick washer so I took it off to get the balancer started and then put back on and tightened it up. Its the bolt listed for an LS1 so it is the proper length.
