2000 LS1 harness to a 94 Z28 M6 Camaro...
ok have a few wiring questions here....
i have lined up my wires for C100 as follows on each plug:
LS1
A PWR INJ Fuse #9
B
C
D
E Serial Data
F PWR PCM Fuse #8
G PWR IGN Fuse #11
H Fan II
J Fan I
K PWR INJ #10
The 94 harness is a little different than the 95 and here is where my questions come up.
LT1
A PWR INJ Fuse #9
B
C
D
E
F PWR Fans/Act Fuse #6
G PWR IGN Fuse #11
H Fan II
J Fan I
K PWR INJ Fuse #10
OK this is what i have wired up above. On the LS1 plug Pin E "Serial Data", i have no serial data to match on the LT1 plug. The only serial data i have is on plug C220 Pin F. Does the LS1 serial data wire Pin E need to go to the 220 plug to match the LT1s location or is it a 12v signal and i need to run a circuit?
Secondly, on the LT1 harness, there is no PWR PCM Fuse #8 wire. This was the orange wire on the LS1 harness. On the LT1 harness there is a "key on" 12v source labeled PWR Fans/Act Fuse #6. Can that be used to power the orange wire (Pin F on the LS1 harness) PWR PCM
Thanks for the help in advanvce!
LS1
A PWR INJ Fuse #9
B
C
D
E Serial Data
F PWR PCM Fuse #8
G PWR IGN Fuse #11
H Fan II
J Fan I
K PWR INJ #10
LT1
A PWR INJ Fuse #9
B
C
D
E
G PWR IGN Fuse #11
H Fan II
J Fan I
K PWR INJ Fuse #10
yea man ive been following that page. i know how t ouse a search function. however those wiring are for a 1995 and the pinouts are a little different if you rear my above statements thanks.
Get rid of that serial data in the C100, it's for the gauges in the LS1 Car. Keep the one in the C220 and run it to pin 2 in the datalink connector.
That orange wire is a fused constant power directly from the battery going to the PCM. Basically it's a wire that always has 12v power, even with the car off. The PCM ignition has to be one that has 12v with the key on, so that Fans/acr Fuse may work for that.
The 1994 doesn't have any orange or pink wires in the other connector on the wheel well?
There isn't a c105 connector on the 94 model. But you amswered my question. The orange wire on the ls1 side of the harness at c100 needs a constant 12v source. When I get home tonight I will see if any of the circuits are constants and tie the orange to that. Everything else should be key on correct
