sn95 swap
Also will start cleaning up and smoothing out the engine compartment while everything is out and get it all painted up with por15.
Rear is at J&E automotive getting late model ford big 9" housing ends installed and shortened two inches per side and the axel tubes welded and brace. Once its back I'll be ordering up strange 35 spline axels, spool, 4.30 gear for it and will then move onto the rear suspension. Plan is to either run team z rear suspension with there relocated upper or may decide to go with wolfe for the rear.
Any chance you're looking to sell the wire harness for the instrument cluster? Any how, good luck w/ your build.
Well decided to just go with a big block as i already have 2 454 short blocks im not using so going to drop one in the mustang.
Team z k-member
Team z adjustable a-arms and caster camber plates and strange single adjustable struts. Coil over kit for the struts will be here next week.
TRZ motorsports double adjustable upper and lowers, spherical bushing, anti roll bar, coil over brackets, and afco double adjustabe coil overs
Racecraft new adjustable lower controll arm bracket for 8.8
Rear housing back from J&E narrowed 2inch, axel tubes welded and braced and late model ford 9" housing ends installed. Spindles are being powder coated right now and rear will be next once I get the coil over brackets and anti roll tabs welded on.
