5.3 swap in to third gen camaro Q's??
A 5.3 seems to be the cheapest route compared to ls1 and its more in my budget. i have a ls1 intake. and looking for cheapest route. so here's for the questions?
should i get ls1 injectors and fuel rail?
Use truck ecm?
are Motor mounts the same as Ls1?
Get Ls1 front accessories?
Use stock exhaust manifolds with what Y-Pipe?
Different Fuel Pump with regulator?
install a cam and springs?
is there any manual tranny that will bolt up thats not sky high other than t56 or should i just get a 4l60e?
Use truck ecm?
Use truck ecm?
Use truck ecm?
Turd Gen Guy
should i get ls1 injectors and fuel rail? yes you should be able to pick one up for cheap
Use truck ecm?idk the best about ecms i know the one i had for a truck the terminals were blue and green. the ones for f-bodys are red and blue
are Motor mounts the same as Ls1?you will need the clamshell mounts and pick up some spohn frame mounts.
Get Ls1 front accessories?i have seen people use the truck accessories but if you do get the car stuff you have to drill one hole in the front. where the iron blocks did not need the hole for truck accessories.
Use stock exhaust manifolds with what Y-Pipe?truck manifolds will not work. i THINK the 01-02 car manifolds will though
Different Fuel Pump with regulator? the stock intank pump will work. but a walbro 255 is like 100 bucks. why not upgrade? and just use the corvette fuel filter that has a built in regualtor
install a cam and springs? i had a 224-228 cam with comp. 918 springs and loved it!!
I personally wouldn't use any other manual transmission other than a T-56 or MN12. I bought my MN12 for $1500 and that's not bad for a 6-speed transmission. If you are going automatic, try to get your hands on a 4L80E instead.
Sure, be sure the injectors are the 28.8lb versions as the 26's max out quickly on a mild 5.3
Use truck ecm?
Go be service number instead of original vehicle
Cheapest is the SBC adapter plates from ebay <$30. Cant use the LSx AC with them though
They fit best. GTO and Caddys are similar but less common. C5 stuff also works but has the vette tax
98-02 Fbody manifolds fit perfect. Early are stainless, later cast iron. Any Y-pipe will be custom made. The 4th gen wont fit and no companies are building them for 3rd swaps yet
Use a walbro or mid 90's vortec truck pump and a C5 filter/regulator combo. Stock pump will not be enough to feed the LSx. It is designed for 43psi, LSx operate at 58psi
Its an extra cost, but sure. LS6 cams are the cheapest and give a good punch for the effort. 224-228 duration cams also play nicely, anything 230+ gets rough to tune according to the performance truck forum
Easiest is to go with a Fbody or GTO T56. Id suggest not compromising on the trans type, if you do you will regret it. I know I did
Read over the TGO sticky and check out some of the builds over there. Dynodanmanda and I are both using a 5.3 and several others are using truck blocks
Use truck ecm?
thanks for the advice fellas. i think thats the route i'll go. 5.3 with ls6 cam or one closely compared with springs, truck ecm, stock fbody exhaust manifolds,and maybe a performance fuel pump with corvette filtler and regulator combo. didnt know the ls engines didnt have return lines to tank i have a 98 ta just havent paid any attention i guess.
if i happen to luck up on a new fbody gas tank will they fit reasonably well?
which oil pan will i need, fbody for sure?
Keep in mind that the 6.0 LG4/LG9 isn't much more expensive than a 5.3, and is significantly more powerful. With all of the other associated expenses and effort associated with the swap, I'd say it's definitely worth the small additional investment to have the bigger motor.
Formerly 99-2door-08/30/2010
looks like buying fbody accessories could get a little expensive, hawksthirdgen sells the whole front accessories for 850.00. seems little high to me any other place to find brackets and all that? like stated above if ....you can find a 5.3 for around 500 bucks ,and to spend 800 dollars for accessories would be a killer.
Here is the idea I had. I have an 89 v8 auto. I've thought of just buying a whole fleet truck or a wrecked truck. Fleet trucks general have great service and are usually mechanically in better shape than private vehicles. If u buy a 1/2 or 3/4 ton 2wd with a 6.0 or 5.3 u have everything u need and a truck to part out or scrap to get some of Ur money back.200k on a fleet truck is like 100k on a private vehicle. So spend wisely. But my question is how much HP gain is there from the 6.0 and will it hurt fuel efficiency since this will be my daily driver.
Doing this swap also, This thread answerd a lot of questions i had for sure. was about to go buy a 4th gen tank this weekend. I just need an oil pan to get this swap moving. Those things must have gold in them becuase dang they are spendy even used. Half the cost of the engine.
