3 wire coolant temp sensor...difference???
Old Aug 9, 2010 | 10:48 PM
Yellowbrother's Avatar
Default 3 wire coolant temp sensor...difference???
is there a functional difference between the v6's vs. 98 ls1???
is there another vehicle/motor that uses the 12551708 temp sensor?
Old Aug 10, 2010 | 08:47 AM
3800RS's Avatar
i believe they are the same if they have the 3 wires
Old Aug 10, 2010 | 12:20 PM
hmmm..cuz there is big price difference between them....
Old Aug 10, 2010 | 05:19 PM
poconojoe's Avatar
$2.62 is a big differance?
98 with a 5.7 uses ECH TS5721 $20.46
98 with a 3.8 uses ECH TS4020 $17.84
Old Aug 10, 2010 | 05:22 PM
poconojoe's Avatar
Define functional differance?
If you mean electricly, I don't think so, but if you mean mechanicly, does having differant threads count?
Old Aug 10, 2010 | 08:11 PM
no1kicker's Avatar
FWIW, I tried to put a 3800 temp sensor in the 5.3L head and the threads were too large. The temp sensor was from a 96 SSEI, and Autozone lists the same part # for the SSEI and a 98 Bird 3800.
Old Aug 10, 2010 | 08:13 PM
what part number are those??? the ones i found for ls1 from auto part stores are 30+ and the v6's are in the teens...big difference when u on a budget...
Old Aug 10, 2010 | 08:15 PM
oh yeah huh...didn't take into account the threading....
functional differences as in...can u take the v6 and plug it into ls1 harness and the third wire to the temp gauge and everything function as if u're using the 98 3-wire temp sensor....but moot question if threading is different...hahahah...
Old Aug 10, 2010 | 09:37 PM
Rick Speed's Avatar
The plug end and wiring is the same. The differance is the thread size.
Old Aug 10, 2010 | 11:14 PM
the_merv's Avatar
Veteran: Air Force
**** mine was $20 at the stealership..
Old Aug 10, 2010 | 11:31 PM
oh really??? hmmm...i didnt check the dealership assuming they were more then the autoparts store...
Old Aug 10, 2010 | 11:37 PM
the_merv's Avatar
Veteran: Air Force
This was a few years ago..maybe they went up.
Old Aug 11, 2010 | 12:10 AM
poconojoe's Avatar
Echlin, NAPA sells it
The list price for a 12551708 is $29 and some change, so net should be a little over $21 at the dealer
