Have new fusebox for engine install (89 Camaro)
which of the wires/connections should i remove?
the new fuse box will run ecm, fans, a/c, fuel pump, fuel injectors, mil lamp, coils, and has 12v switched, and 12v. it seems (key word) that i can just remove the box but i want some confirmation on it.
i only want to keep the stereo, lights, and heat and whtever is needed. im trying to see if A) someone has a diagram of what interior fuse box wires go where , and B) if the internal box can be removed with what ive listed for the new fuse box.
im also changing the firewall connector to a caspers 32 pin connector.
