Help FAST!! please
inj pulse at both banks at 1200 rpms is about 6.2mV
MAP kPa 91
map V 4.27
Baro kPA 91
tps at 0% throttle is 0.51V and at 100% is about 4.20V
fuel psi is constant at 58psi
car is speed density. rear O2s deleted, MAF deleted. IAC tuned out.
Any ideas? We have Charlotte Auto Fair in two days for the show and gotta figure this out.
I had a battery terminal issue which gave me fits until I found it. Ironically the new terminals from the previous owner weren't setup well. Even though the cables and terminals were new they still had conductivity issues because the install was a bit of a hack job and the new engine drew more current.
Recheck TPS, could be entering clearflood somehow preventing injectors from firing at crank speeds.????
is PCM programmed correctly for the injectors? flex fuel programming with normal injectors?
the kPa is at about 1200 rpms. idle is around 1150. cam is a custom grind 24x,25x
pcm was programed for this motor in the car it came out of. if the computer sat with no battery to it for, say 4 months, could it have lost its tune in the pcm? ok update..... now i went outside and put a new cam and crank sensor in it. motor spins over and hits one time and cuts off. not getting an injector pulse while in run now. but injectors have power key on... VATS is disabled btw,
