Temp sensor?
Old Sep 1, 2010 | 05:30 PM
deuce4935's Avatar
Default Temp sensor?
Anyone know how the 98' coolant temp sensor is suppose to be wired? i'm trying to distinguish which is the pwr, ground, and signal for the gauge.
Old Sep 1, 2010 | 06:28 PM
poconojoe's Avatar
One wire is ground
One wire is the sensor for the PCM and the other wire is the sensor for the gauge
Old Sep 1, 2010 | 08:51 PM
deuce4935's Avatar
Any ideas as to which color represents what. I'm sure that black is ground, but then theres a red and green wire, these things aint exactly cheap and easy to find at the local parts store.
Old Sep 1, 2010 | 11:13 PM
poconojoe's Avatar
Pin, Wire Color, Circuit No., Function
A, BRN, 718, Engine Coolant Tenperature (ECT) Sensor Ground
B, YEL, 410, Engine Coolant Temperature (ECT) Sensor Signal
C, DK GRN, 135, Engine Coolant Temperature (ECT) Sensor Output
Old Dec 16, 2010 | 11:07 AM
Ford_Assassin's Avatar
Anyone have a part number for a '98 LS1 coolant sensor? The 3 wire thing is hard to find vs the later 2 wire style.
Thanks!!
Old Dec 16, 2010 | 11:38 AM
bjamick's Avatar
http://www.gmpartsdirect.com/results.cfm part #12551708
Old Dec 16, 2010 | 02:15 PM
the_merv's Avatar
Veteran: Air Force
Pin C goes to the Gauges, the other 2 go to the PCM.
Old Dec 16, 2010 | 03:53 PM
flame's Avatar
Thanks!!
The Standard part number is TX111
Old Dec 17, 2010 | 05:50 PM
Monte4ever's Avatar
Any after market gauges work with that 3 wire sensor?
Old Dec 18, 2010 | 08:18 AM
RGSS's Avatar
If the resistance/temp value of the GM sensor is the same as the aftermarket sensor you should be able to use it. You would have to do some research to determine that, though.
Good info here.
I am doing an LS swap into my '96 and want to keep all the gauges in my original cluster functional for a seamless integration.
Old Dec 18, 2010 | 08:33 AM
garys 68's Avatar
Not sure but here's an old post with the 98 resistance/temp values.
https://ls1tech.com/forums/conversio...auge-59-a.html
