Lil Red Riding Hood 91 s10
And the accessories its just going to be a drag truck if anything so just water pump alternator and pulley is all im using......
I actually was going to go with a truck bracket, but i just found out it wont work with the ls6 intake, soooooo I might have to run a truck intake, buuutttttt there's a chance it wont clear the hood!
i didnt know that thanks for the info!
https://ls1tech.com/forums/conversio...r-intakes.html
and water pump.
or use car wp just pulled off the shaft around 1/2in. so u can use the ls6 intake. the truck wp water neck will be in the way of the tb arm. the truck bracket is huge, and heavy and will prolly hit your hood.
I used the truck bracket on my 2nd gen s10 swap, just cut the bottom part off and used the top part for an alt bracket. it clears my stock 2nd gen hood. I also know a friend who used the same bracket for a 1st gen swap stock hood there as well. Just thought i'd let ya know. LS1 intakes were used on both these swaps btw. Takes some fabrication, nothing serious though, i did it all with a hand grinder lol. Both trucks used the stock truck crank pulley, stock truck tensioner on the passenger side, stock truck waterpump and an alternator from a 90's 1500 truck.
Hope that helps if you were interested!
#35
ok im new to the swap setups as most know but im doing a build thread which will included everything as far as how to wire the ls1 in s10 (what wire goes where and so further) and now im stuck on the fuel setup i have done a setup up of what i think is going to be the correct way of setting up..... please correct me if im wrong....
this will be a complete aftermarket setup
